eg window wont roll up. broken window arms?
Old 08-03-2010, 04:17 PM
94cxhatch's Avatar
Default eg window wont roll up. broken window arms?
ok so i let my friend drive my car and he chirped way too hard and my window got un-tracked. lol. so i tried fixing it and i noticed the arm on the right that is supposed to be inside the rail came off, and i guess it got bent..does anyone know how to fix this??
in the third picture you can see how the arm ball joint is on top of the rail, not inside. and that the arm is bent. i can get the arm inside the rail but it doesnt roll up straight. any way to fix this?
Old 08-03-2010, 04:20 PM
EJeff8's Avatar
Default Re: eg window wont roll up. broken window arms?
A new regulator for like $35 shipped at rockauto.com. If you can't figure out this problem, I'd just get a new one for basically dirt cheap. I have a power one in my driver door EJ and it works beautiful.
Old 08-03-2010, 04:22 PM
em1effekt's Avatar
get a new one...worth it..
Old 08-03-2010, 04:30 PM
94cxhatch's Avatar
alright thanks guys this one right? http://www.rockauto.com/catalog/raframecatalog.php
and how the f would i swap that?
Old 08-03-2010, 04:31 PM
EJeff8's Avatar
Remove the bolts that hold the arm and it slides right out the hole in the bottom. It'll take you an hour max. Remember. PULL THE WINDOW OFF FIRST! Aha.
Old 08-03-2010, 04:35 PM
EJeff8's Avatar
I actually don't see a front left manual regulator... hm.
Old 08-03-2010, 04:40 PM
em1effekt's Avatar
that link didnt show us anything lol
but get the one for your car make sure its manual...and for the side you need it for...
94cxhatch's Avatar
**** youre right.. is the drivers side window the same as the 4 doors?
Old 08-03-2010, 04:48 PM
EJeff8's Avatar
Look through all the trim models. You just need a manual regulator for a front left COUPE 92-95. The doors are sized diff. from Coupe to Sedan.
Old 08-03-2010, 04:50 PM
94cxhatch's Avatar
k i found one.
http://cgi.ebay.com/ebaymotors/1994-...Q5fAccessories
i dont get how to unscrew the bolts inside though
Old 08-03-2010, 04:52 PM
EJeff8's Avatar
^NO! No ebay. On rockauto, the DX trim model has the regulator you need under it.
There are brass covered bolts lining the middle of the door. Unscrew them after the window is taken off, pop the crank off and the regulator will slide right out the large hole in the bottom of the door
Old 08-03-2010, 04:53 PM
94cxhatch's Avatar
oh alright haha. thanks alot!
Old 08-03-2010, 04:56 PM
em1effekt's Avatar
ebay gots em for like 5 more bucks...
Old 08-03-2010, 04:58 PM
EJeff8's Avatar
Bc yours is mani, it'll be like $45 shipped. still no biggie bro. But all the bolts you need to take off look you right in the face on the outside of the door. And the window is on by two bolts, unscrew the bolts and it slides up and out.
Old 08-03-2010, 04:59 PM
EJeff8's Avatar
So more expensive and it's an ebay product?
RA is the place to go.
Old 08-03-2010, 06:33 PM
94cxhatch's Avatar
alright just making sure..is this one fine?
Part # 740448??
Old 08-03-2010, 07:05 PM
EJeff8's Avatar
^Linking to rockauto doesn't work, it just takes you to the default page. I'll tell you.
Go to 1994 Honda Civic DX tab, click Body - Interior. Click Window Reg. Choose Front Left MANUAL Regulator. It's priced at $40 but shipping will probably make it to $45. BAM! It'll be there in two days or less ON THE CHEAPEST FORM OF SHIPPING. If you spend an extra $30 for it to arrive on the same day, I'll find you and slap you k? Rockauto is amazing. I've bought a knock sensor and regulator from them so far. Top notch and you get a free magnet!
Old 08-03-2010, 07:24 PM
94cxhatch's Avatar
haha yea thats what the link was to. thanks for the help.
Old 08-04-2010, 11:34 AM
EJeff8's Avatar
^If you need help mounting it in a few days, just a PM me. It's not too difficult and I've dealt with power. Crank should be a breeze.
Nedrobmas
05-18-2017 03:42 PM
ekcivic9
03-27-2006 01:47 PM
pinoyboy204
07-30-2003 06:17 PM
Quick Reply: eg window wont roll up. broken window arms?
