car does NOT start
car does NOT start
ok car was stolen and recovered,
now im doing the rebuild and trying to get it running again
CAR INFO:
96 honda civic DX(5speed)
95 obd2a (b18C1) boosted
CHIPPED P28
OBD2A harness
OBD1 ECU
PARTS REINSTALLED
THROTTLE BODY
FUEL RAIL
INJECTORS
VALVE COVER
obd2a to obd1 step down
ok so here is the problem car cranks,turns over and sound like its gonna start but doesnt
I CHECK SPARK,INJECTORS(NEW), COMPRESSION,FUEL PUMP,MAIN RELAY(ALL GOOD BUT MAIN RELAY)
I CHANGED MAIN RELAY NOW IT SOUNDS LIKE ITS GONNA TURN ON BUT NEEDS HELP
I HAVE CEL(havent hooked up computer yet intill this coming thursday)
i really dont have any idea left besides maybe ground,
help me out Honda-Tech!!!!! please
CAR INFO:
CHIPPED P28
OBD2A harness
OBD1 ECU
PARTS REINSTALLED
THROTTLE BODY
FUEL RAIL
INJECTORS
VALVE COVER
Re: car does start
What did you find? Some details would help.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Re: car does start
A bad wire harness is possible. It is called CEL code 0 when the CEL remains on steady both with and without the service connector jumped. It indicates that the ECU is not getting power or ground. Start by checking fuse 44, 31, or 18 and whether the G101 ground on the thermostat housing is clean and tight.
Bsixteen_CRX
04-08-2008 08:11 PM
biggee
07-04-2007 11:04 PM
