Just replaced drive belts. Now it squeals at start up only....
Old 07-31-2010, 10:21 AM
Speardog's Avatar
Default Just replaced drive belts. Now it squeals at start up only....
I just replaced all the belts. Is there a reason why they squeal at start up for only a few seconds. They are all tight. Could a belt being too tight cause the squeal?
Old 07-31-2010, 10:47 AM
Matt93eg's Avatar
Default Re: Just replaced drive belts. Now it squeals at start up only....
Re-Check the tension on the Alternator belt to make sure its tight enough.
Old 07-31-2010, 11:26 AM
Speardog's Avatar
If anything, I think it would be on the tighter end of the spectrum
Old 07-31-2010, 06:40 PM
Speardog's Avatar
anyone else?
Old 07-31-2010, 06:43 PM
madpipr's Avatar
push down on all the belts. if there is roughly .25" in play, its good. too much or too little, adjust accordingly.
Old 07-31-2010, 06:44 PM
MiG-21 superfan
builthatch's Avatar
a squeal is from slipping. that's all it can be. if it's on startup the initial torque of the pulley going from 0 rpm to idle speed is too much and overcomes the belt tension. it's very likely a belt is loose. if you think you set it too tight, you might have, but it has obviously loosened up or there is some sort of contamination on the pulley or underside of the belt. it is also possible but not likely that the size of the cross-section of a belt is enough (either too wide or shaped oddly) to cause it to seat poorly on the pulley.
good luck.
mikey88
04-19-2017 10:57 AM
phat00civic
03-07-2012 06:30 AM
CALC!_JUST_du_IT!
06-10-2008 12:55 PM
JMod
16
06-23-2005 11:49 AM
keithv
08-07-2002 04:40 AM
Quick Reply: Just replaced drive belts. Now it squeals at start up only....
