92 civic DX won't start? help?
Hello, I recently got a 92 civic DX as a project car. For now I was driving it around with the original engine in it. I deliver pizza for a living. It started after i was off work when I went to leave. I tried to start the car and the starter would turn but the car wouldn't kick over. I tried to push it down the street to kick start it by throwing it into first gear. But it still would not run. I have changed the fuel filter and pump. The only issue I have is the fuel pump will not run. The old one didn't nor will the new pump. I have checked all the fuses. Does anyone know of this issue?
Is the ECU bad? Relays that could be bad? All the battery power is fine. I do not believe it is voltage issues. My step father is a former mechanic and even he can not figure out what is going on. Any help to this problem is high appreciated!
Thanks in advance!
Thanks in advance!
Re: 92 civic DX won't start? help?
Thank you. I ripped out the main relay today. It does look charred! I called Advance Auto parts and it is $60 for a new relay. I don't know how to solder, and I do not want to start on this and screw something up.
Here is a picture. It is not the best quality. IF you can tell I don't know:
brixcivic
03-17-2010 04:43 AM
