Step down/ wiring problems
Old Feb 24, 2009 | 10:27 AM
egreenmachine's Avatar
Default Step down/ wiring problems
Need help with a wiring diagram, I purchased an ls/vtec swap from a guy awhile back and it consist of a 2000 obd2 gsr head on a b18a bottom end. Problem is instead of getting a step down harness the guy used an obd1 harness and cut and spliced the obd2 distributor plugs onto the harness. The swap was running, however he used just crimps to attach the wires and some came undone. What I am looking for is a layout for the obd1 distribtor plug wiring and obd2 distributor plus wiring so I can fix the wires that have come apart. If anyone can help with this it would be great thanks.
Break down:
94 eg shell
obd1 harness
obd2 distributor and head
Old Feb 24, 2009 | 11:05 AM
CivicSpoon's Avatar
Default Re: Step down/ wiring problems
If you can, match the wires by location, not by color.
Project H
Dec 26, 2010 05:22 PM
natecivic92
Jun 22, 2008 07:40 PM
a1320addict
Aug 19, 2006 12:11 PM
Honda_Tengoku
Sep 12, 2004 02:08 PM
