NOt sure about D16 and D15
Old Feb 26, 2009 | 08:03 AM
LSXFEIND's Avatar
Default NOt sure about D16 and D15
is a d16vtec worth 380.00?? with 80,000miles but just the longblock no distributor or tranny nor axles or harness???
Old Feb 26, 2009 | 08:04 AM
LSXFEIND's Avatar
Default Re: NOt sure about D16 and D15
by the way whats the differnce in HP from a d16 and a d15 both vtec?
Old Feb 26, 2009 | 08:13 AM
ajason24's Avatar
go to a website that sells swap and compare the motors
and that is an alright price
what are you looking to do with the motor
Old Feb 26, 2009 | 08:14 AM
LwdJdmR's Avatar
D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
1992-1998 Honda CRX VXi EG1 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp (128 ps) @ 6800 rpm & 115.9 ft·lbs (14.1kg/m) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Head Code : P08
Piston Code: P08-010
Fuel Control : OBD-1 MPFI
[edit]
D15B (D15Z7) (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.6:1
Power : 128 hp (130 ps) @ 7000 rpm & 102 ft·lbf (14.2kg/m) @ 5300 rpm
Fuel Control : OBD-2 MPFI
D15Z1
VTEC-E
Found in:
1992-1995 Honda Civic VX
1992-1995 Honda Civic VEi (European Market)
Rod Length : 137 mm
Compression : 9.3:1
Power : 90 hp (67 kW) @ 5600 rpm & 98 ft·lbf (133 N·m) @ 4800 rpm
Valvetrain : SOHC VTEC-E (4 valves per cylinder)
ECU Code : P07
D15Z6
VTEC
Found in:
1995-2000 Honda Civic 1.5 iLS (European Market)
Rod Length : 137 mm
Compression : 9.6:1
Power : 115 hp (86 kW) @ 6500 rpm
Torque : 100 ft·lbf (141 Nm) @ 4800 rpm
VTEC Switchover : 2500 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
Fuel Control : OBD2a PGM-FI MPFI
[edit]
D15Z7
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
ECU Code : P2J
[edit]
D15Z8
VTEC-E
Found in:
1997-2000 Honda Civic LS (European Market)
Compression : 9.6:1
Power : 84 kW (114 hp) @ 6500 rpm
Torque : 134 Nm (95 ft·lbf) @ 4500 rpm
Head Code : P2J
ECU Code : P2P
Fuel Control : OBD2 MPFI
Old Feb 26, 2009 | 08:17 AM
LwdJdmR's Avatar
D16W7
Vtec-E
Found in:
2005-2007 Honda Civic Vti-L/ Vti (Asia)
Displacement:1,590 cc (97 cu in)
Compression : 10.9:1
Power : 115hp 5600 rpm & 152Nm 4300 rpm
Valvetrain : SOHC
Redline 6100 rpm
Limit 6200 rpm
ECU Code: PM12
Also found in 2001-2005 Honda Civic (Europe)
Same as above, except:
Power: 110hp (81kW) @ 5600 rpm & 152 Nm @ 4300 rpm
Redline 6100 rpm
Limit 6200 rpm
D16Y1
Found in
1992-1995 Honda Civic VTi (AUS)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Compression : 9.3:1
Power : 129 hp (96 kW) @ 6600 rpm & 107 ft·lbf (145 N·m) @ 5200 rpm
Redline : 7200 rpm
Head Code : P08
ECU Code : P28
D16Y5
VTEC-E
Found in:
1996-2000 Honda Civic HX
1996 Honda Civic EX(sedan Peruvian version)
Rod Length : 137 mm
Compression : 9.4:1
Power : 115 hp (86 kW)@ 5600 rpm & 104 ft·lbf (141 N·m) @ 4500 rpm
Head Code : P2J
1996-2000 VTi (Phils. & NZ)
Compression :
Power : 127 hp (95 kW)@ 5800 rpm
Valvetrain : DOHC VTEC-i
Head Code : P2J
ECU Code : P2M
Piston Code : P2MY
D16Y8
VTEC
Also available in New Zealand under the code D16Y6
Found in
1999-2000 Honda Civic SE 1.6 Vtec (UK)
1997-1998 Honda Civic EX Sedan
1996-1998 Honda Civic EX Coupe
1996-2000 Honda Civic EX (US)
1996-2000 Honda Civic SI (Canada Only)
1997-2000 Acura 1.6EL (Canada Only)
1996-1997 Honda del Sol Si
Rod Length : 137 mm
Compression : 9.6:1
Valvetrain: SOHC VTEC
127 hp@6600 rpm
102ft·lbf (144 Nm)@5500 rp
Head Code : P2J
Piston Code : P2P
Redline 6900 rpm
ECU Code : P2P
D16Z6
Found in
1992-1995 Honda civic SI
1992-1995 Honda Civic EX, EX-V
1992-1995 Honda Civic ESi (European Market)
1993-1995 Honda Del Sol Si (US)
1993-1995 Honda Del Sol ESi (European)
Compression : 9.2:1
Power : 125 hp (93 kW) @ 6600 rpm & 106 ft·lbf (144 N·m) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Head Code : P08
ECU Code : P28
enjoy!
Old Feb 26, 2009 | 08:18 AM
LSXFEIND's Avatar
im going to put in a EF and make it run pretty hard lol but people are telling me that its too expensive for that prive it should at least come the distributor and a harnes?
Old Feb 26, 2009 | 08:25 AM
LSXFEIND's Avatar
Awsome Thanks
Originally Posted by LwdJdmR
D16W7
Vtec-E
Found in:
Valvetrain : SOHC
Redline 6100 rpm
Limit 6200 rpm
ECU Code: PM12
Redline 6100 rpm
Limit 6200 rpm
D16Y1
Found in
Compression : 9.3:1
Redline : 7200 rpm
Head Code : P08
ECU Code : P28
D16Y5
VTEC-E
Found in:
Rod Length : 137 mm
Compression : 9.4:1
Head Code : P2J
Compression :
Head Code : P2J
ECU Code : P2M
Piston Code : P2MY
D16Y8
VTEC
Found in
Rod Length : 137 mm
Compression : 9.6:1
127 hp@6600 rpm
Head Code : P2J
Piston Code : P2P
Redline 6900 rpm
ECU Code : P2P
D16Z6
Found in
Compression : 9.2:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Head Code : P08
ECU Code : P28
enjoy!
Old Feb 26, 2009 | 08:28 AM
LwdJdmR's Avatar
well you live in SD i dunno if you would be willing to drive all the way to la for a motor.
I dunno if you ever heard of http://www.gspeedcorp.com/ pretty cool guys.
I picked up a d15b non vtec long block. for 250 came everything but tranny and full engine harness. give them a call. and ask if they can get you a good price. oh and if you do drive down to their warehouse. you could even pick the engine you want!
Old Feb 26, 2009 | 08:35 AM
LSXFEIND's Avatar
Oooh thanks bro will consider
Old Feb 26, 2009 | 08:36 AM
LwdJdmR's Avatar
anytime.
gl with your car.
TravisCadello
18
Nov 29, 2015 06:52 PM
driftguy2008
10
Feb 27, 2013 05:52 PM
jdmjonny21
14
Jun 28, 2012 02:30 PM
KRZRICAN
May 20, 2009 03:52 PM
efjones9
Dec 5, 2008 08:19 AM
