99-00 si foglights
ok, i need someones help on how tocut out the inserts for my foglights and what tools to use. They are aftermarket foglights that you see on ebay all the time so if anyone can help it will be appreciated.
Ladies and gentlemen we are floating in space...
You cut the inserts by drilling holes into the points marked on the back of the bumper and then using the cutting tool of your choice to connect the outside of the circles you've drilled (which will make the necessary section fall out). It's actually really easy; it'll be clear once you look at the back of the bumper. The spots look like targets- they have a point to center the drill and an outline to show which size drill bit to use.
yea man just put in a few holes where it says, and connect the dots. it's pretty easy.
also make sure you separate the left & right brackets from each other before you get started. I mixed them up on accident when I took everything outand had to try all combinations to get it sorted right lol.
btw- i most likely got the same fogs as you...beware, the switch they provide is a P.O.S. it doesn't illuminate when the fogs are on like they should, and it gets stuck (in both directions). so when they're off it's hard to get them back on, and vice versa...i'd recommend getting a different switch- i know i will be soon.
Slewbang
Mar 10, 2006 12:31 PM
boosted96midorihatch
Oct 5, 2004 09:23 PM
Gump
May 4, 2002 04:29 PM
