Performing 100k maintenance - check out my parts list - what else should I add?
Old Feb 26, 2009 | 03:19 AM
hotcivicsi's Avatar
Icon5 Performing 100k maintenance - check out my parts list - what else should I add?
98 B18B1 motor
-fuel filter
-pcv valve
-distributor cap
-distributor rotor
-oil pan gasket
-timing belt
-cam seal
-belt tensioner
-tensioner spring
-water pump
-thermostat
plugs and wires are fairly new
going to be also changing the radiator fluid
What other gaskets/parts do I need for the timing belt job???
Thanks
Old Feb 26, 2009 | 03:36 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Performing 100k maintenance - check out my parts list - what else should I add?
oil pump seal, rear main seal, cam seals, cam seal plug, valve cover gaskets, spark plug seals........
I would suggest getting Genuine Honda parts instead of others (Advance Auto, Autozone, etc.) Nothing beats original factory quality and reliability.
Old Feb 26, 2009 | 03:56 AM
hotcivicsi's Avatar
I'm definetly getting all OEM parts. Valve cover gasket was done recently so I'll reuse that, havent had issue's reusing those in the past.
Old Feb 26, 2009 | 04:04 AM
90Rexx's Avatar
why would he replace his rear main seal and oil pump seal for maintenance lol? thats just plain stupid. dont fix what isnt broken my friend.
Old Feb 26, 2009 | 04:06 AM
90Rexx's Avatar
dont re-use that cover gasket. even if you havnt had problems, they are cheap enough where you shouldnt have to.
replace the belt tensioner while your doing your timing belt! alot of timing belt failure is due to bad tensioners.
also whole your cover is off you should do a valve lash adjustment. and you should consider seafoaming the car.
* sorry double post.
Old Feb 26, 2009 | 04:54 AM
hotcivicsi's Avatar
sweet thanks for the advice guys....Im planning to seafoam actually this weekend before I do my oil change
Ill add the cam seals, tensioner and spring to my list of parts
We are up to $325 in parts
DIY and not paying for labor = sweeeet
Old Feb 26, 2009 | 05:23 AM
iliv2xlr8's Avatar
Change tranny fluid (& filter if auto), 4whl alignment.
When you flush the radiator for new, I recommend using Prestone radiator flush. You essentially drain the coolant, fill with water and Prestone, drive it 30 minutes and reflush. You will be amazed of the crap that comes out of your cooling system.
Old Feb 26, 2009 | 05:33 AM
hotcivicsi's Avatar
tranny fluid ill change when I replace my axle since the boot is torn.
doesnt Prestone radiator flush hook up to your hose? which I heard is bad
Old Feb 26, 2009 | 08:27 AM
NVturbo's Avatar
O.G. triple O.G.
What's stupid is not doing it?! I bet you have never changed a rear main seal before. Just because it's not "broken" doesnt' mean the OP can't replace them. Dumba55 people, I swear.
Old Feb 26, 2009 | 08:55 AM
iliv2xlr8's Avatar
Post Re: Performing 100k maintenance - check out my parts list - what else should I add?
No. You simply pour it into the system.
-drain coolant
-fill with water and Prestone
-drive for 30 min.
-drain cleaner & water mix
-flush with a waterhose while car is idling & heater is on until you see clear water
-refill with coolant
Stuff works great. It also helps clean out those block passages.
-XLR8
Old Feb 26, 2009 | 08:57 AM
arrocha87's Avatar
id say check your ball joints and tie rod ends, also your motor mounts. and replace if necesary.
Old Feb 26, 2009 | 10:37 AM
D16SohcVtec's Avatar
If you are going to be replacing the rear main seal. You might as well just replace the clutch while your at it. Your going to have to pull the tranny, remove the clutch, and the flywheel in order to get to that seal.
Old Feb 26, 2009 | 11:25 AM
mortificationrock's Avatar
^^ exactly. Thats why maybe the other guy said not to do it. 1 **** leads to = another. Then you end up rebuilding the whole engine...LOL. Atleast thats what happened to me.
Old Feb 26, 2009 | 01:35 PM
brutekiller787's Avatar
yea. you could get get a new engine too. if you were planning to do a swap you might as well do it now.
S2KILLA
Nov 4, 2005 05:18 PM
StatGSR
Jul 21, 2004 07:23 PM
Eluder200K
Jan 27, 2003 01:50 PM
deviant1
Dec 24, 2002 06:05 PM
