brakes lose pressure while idling, 94 civic
Old Feb 25, 2009 | 11:59 AM
urbach's Avatar
Default brakes lose pressure while idling, 94 civic
At idle the brake pedal slowly depresses to the floor. If I let my foot off and press again, it regains original pressure but then slowly depresses to the floor again. If I give it a little throttle above 1000 rpm, the brakes maintain hydraulic pressure. I can't find any sign of leaks, and I've bled it to be sure there's no air. Given the dependence on engine RPM, my guess is that the brake booster or master cylinder have gone bad. Any advice?
Old Feb 25, 2009 | 01:07 PM
Former User's Avatar
Default Re: brakes lose pressure while idling, 94 civic
Try these tests:
Old Feb 25, 2009 | 01:29 PM
trustdestruction's Avatar
hmm i have a similar problem but idk if it's a problem...
RonJ: If I am idling right after driving, the idle is a little high (~1.1k) but after a few seconds it drops to normal. I assume this to be normal. However, when the idle drops to normal, i feel the brake pedal go down a little bit... not a lot, just a tiny bit. I'm not sure if it's suppose to do this or not.
Old Feb 25, 2009 | 01:36 PM
Trust, it doesn't sound like a major problem, but you may want to test the check valve.
Old Feb 25, 2009 | 02:10 PM
i checked it and it's fine
thanks
i'm done with my short little threadjack
Old Feb 25, 2009 | 03:21 PM
urbach's Avatar
RonJ: Thanks for the info. It failed functional test #1 and passed the other tests, so it appears the booster is ok. Today while driving home I noticed that I'm now starting to lose substantial braking power, and it's getting a little dangerous. The master cylinder, lines, and calipers are all original. I've just ordered a new master cylinder. I'd rather not have to replace the calipers if possible--is there an easy way to test for faulty caliper or lines?
Old Feb 25, 2009 | 03:55 PM
schwazel's Avatar
it probably wont need calipers. mos def sounds like a master cylinder to me. depending on how bad the master cylinder is, you probably wont really be able to check the calipers for piston movement.
Old Feb 25, 2009 | 07:03 PM
I agree. The master cylinder is the prime suspect.
Old Feb 26, 2009 | 04:01 AM
urbach's Avatar
Thanks guys. Hopefully this will do the trick.
Old Mar 10, 2009 | 04:10 PM
urbach's Avatar
I replaced the master cylinder, and no more problem. Many thanks!
jvr
Jun 18, 2021 09:42 AM
sohcef9
Nov 4, 2009 01:27 PM
slim9300
Jul 14, 2004 10:14 AM
slim9300
May 10, 2004 07:03 PM
