Battery light, CEL, speedometer problem
Old Feb 25, 2009 | 07:35 AM
silverbullet9626's Avatar
Default Battery light, CEL, speedometer problem
it only happens in the morn or at night when it is really, cold like in the 20's and below. when i turn the key to on position the oil light, cel, brake and seatbelt light come on but not the battery. when i start the car it throws a cel almost immediatly and when i drive it the rpm's drop quick between gear changes also my speedo dosen't work when this happens. once it has warmed up i can cut it off turn the key to on and the batt. light comes on along with all the other lights and runs fine. i have tried the service connector on the pass. side the only code it throws is the knock sensor which i have had since i bought my swap. by the way my car is and 96 ej6 with a jdm 99 si b16a obd2 ecu. i am currently using the jdm under hood fuse box too if that matters.
Old Feb 25, 2009 | 08:06 PM
Default Re: wierd problem
17 views and no reply. do i got ya stumped??
Old Feb 26, 2009 | 07:18 AM
Default Re: weird problem
yea i definitely got some people stumped on this one
Old Feb 26, 2009 | 07:21 AM
slo_hatch's Avatar
check your grounds?? idk what it could be but maybe your grounds are messed up. sounds different kinda but i had a similar problem with my speedo and my lights would dim and the cluster lights wouldnt work...my alternator was bad so it wouldnt keep the battery charged. maybe a couple of things to check on. idk what else to tell you besides start checkin **** and replacing it.
Old Feb 26, 2009 | 07:24 AM
jdm_zew's Avatar
New User
im think it might have an low charging out out, i have that happen in my 95 honda accord, check for alternator regulator out put charging..
Old Feb 26, 2009 | 07:33 AM
i also forgot to mention that i am using the jdm harness with the jdm ecu
Old Feb 26, 2009 | 07:39 AM
bossm's Avatar
k what motor is in the car
Old Feb 26, 2009 | 07:45 AM
jdm b16a car is 96 dx coupe
Old Feb 26, 2009 | 07:54 AM
bossm's Avatar
wow im stumped when you did the swap did you connect all the sensors right and did you wire the ecu right??????
Old Feb 26, 2009 | 08:00 AM
yup never took the harness off the motor except to extend wires because of the jdm harness being backwards and i only had to extend three of them. working on getting a 96-98 ex harness so i can pass emissions
Old Feb 26, 2009 | 08:37 AM
gundamtyper's Avatar
i did a US 97 b18c1 obd2a swap into a 99 civic dx. the 97 p72 ecu was really sensitive to emission sensors (giving me a couple of CEL's). i was also having the same problem with the lights dimming at a certain rpm level. i replaced the 97 ECU with a 99 gsr p72. the 99 p72 makes the engine run way better and i got no more CEL's and my lights did not dim any more. dont know if this will solve your problem though.
i would also agree with previous posts on checking your wiring for correct grounds and replacing any old electrical parts of the motor (sparkplugs/wires, dist. cap/rotor, starter, alternator). unless the engine was totally trashed when you got it, i think the ditributor should be ok, though.
Old Feb 26, 2009 | 10:33 AM
i replaced everything that you suggested except starter and alternator before the swap
Old Feb 26, 2009 | 07:48 PM
bump to tha top
Old Feb 28, 2009 | 08:23 AM
up up up
Old Mar 3, 2009 | 07:32 AM
did u check the alternator to see if it is ok and did u check grounds on your wiring?
Old Mar 3, 2009 | 11:49 AM
Uberfit's Avatar
you say its only happening when its really cold right? maybe the battery needs some more fluid/acid because it is getting to cold to produce proper current. or maybe you have some kindof vacuum leak that's causing the rpm drop, but once the engine is warm the metal or gasket expands enough to seal it again... I'm taking a shot in the dark and I am no mechanic, but it might get you thinking along other lines that might help... because it seems like its a problem with it being cold, not in the wiring and such.
Old Mar 3, 2009 | 12:16 PM
Former User's Avatar
Try replacing fuse 15 (7.5A) under the dash with a new one. Is it loose? Also inspect the terminals for damage or corrosion.
Old Mar 3, 2009 | 05:00 PM
your absolutly right it is def. somthing to do with the cold, and i just replaced my I.M. gasket like two weeks ago along with the iacv. i know i dont have any vac leaks because i checked vac. hose before i went into buying a new gasket and 160.00 iacv. i havent checked the battery or alt. though
Old Mar 3, 2009 | 05:01 PM
what would that fuse be for
Old Mar 3, 2009 | 06:35 PM
The dash battery/charge light and the alternator.
Old Feb 24, 2011 | 07:06 AM
well my problem went away for a while and now its back. i have narrowed it down to thinking that the wires under the dash are too cold to carry the proper current to the cluster. i got off work last night and the prob occurred again as i drove the car and it began to warm up the prob didnt go away after i cut it off and back on. then i drove the car with the recirculating air on so warm air flows through the dash from the bay and not a minute later my speedo started workin. i stopped and restarted it and shazzam workin fine. the cel it is throwing is the ELD. also the idle surges at a stop. i have no vac leaks and have a new iacv
Old Feb 27, 2011 | 07:54 AM
bump
Old Feb 27, 2011 | 09:16 AM
Default Re: Battery light, CEL, speedometer problem
First, do yourself a favor and create more descriptive thread titles -- edited.
Second, click on the fuse 15 TSB in my signature.
rayzian
13
Feb 22, 2018 04:54 PM
vegas hoe
Transmission & Drivetrain
Jun 3, 2009 02:12 PM
HondaPH22
Jul 17, 2006 09:26 PM
99PreludeSh
Jun 8, 2006 11:39 AM
Cielmerlion
Feb 21, 2005 01:21 PM
