Launch control rpm point ? WHATS A GOOD RPM ?
Old Feb 25, 2009 | 06:05 PM
krysted9354's Avatar
Default Launch control rpm point ? WHATS A GOOD RPM ?
ok, for all motor cars wat would be a good rpm launch control setting,
this guy at the billard said his d16 all motor is set at 3,400 or 3,500 would he be able to even launch it that lwo rpm ?
Old Feb 25, 2009 | 06:12 PM
kaminam's Avatar
Default Re: Launch control rpm point ? WHATS A GOOD RPM ?
it depends the tires, but 3.5 -4k would be ok
ajason24's Avatar
yup. its a d16
Old Feb 25, 2009 | 06:22 PM
tercel95's Avatar
Phearable.net set my all motor b16 at like 4800. I think it is a little high for the street though...
Old Feb 26, 2009 | 12:41 PM
ok, somine is at 3,40 for the street ,its a all motor d16 170WHP, with vx wheels and fuzion tires, so for daily driving light nurning 3.400 would be fine right ?
Old Feb 26, 2009 | 02:04 PM
Joeski99Si's Avatar
You need to figure out what the best rpm is ! just try launching at diff. rpms. all cars are different.
With that being said i wouldn't set any launch control for now , untill you have sometime to play around and find out what rpm is best !
Old Feb 26, 2009 | 02:06 PM
P12 EG6's Avatar
well i set mine at 6900 on 23"slicks, no but for street i would say around 4K it just depends if you wanna underlaunch or launch hard and feather it untill you get traction.
Old Feb 26, 2009 | 02:29 PM
bossm's Avatar
godddddddd dammmmm i had mine at 4,500 and when i dump the clutch i still dont have traction 1st gear but again this was on street tires at the track and i didnt really wanna warm up my tires because i am trying to make them last...lol
Old Feb 26, 2009 | 02:37 PM
Schister66's Avatar
Man U FTW
It really depends on the setup, powerband and traction. On the street, i have my GSR limited at 5000rpm, but that may change soon. As for the track, i run a little higher...slicks i run around 7k
Old Feb 26, 2009 | 04:17 PM
ok also what the difference with fule cut launch contorl and ignition cut ??
which one is the one that splatter and makes flames come out and detonates ??
and what are cons and pros ?
Old Feb 26, 2009 | 05:28 PM
Schister66's Avatar
Man U FTW
I'm not entirely sure on the difference between the ignition cut and fuel cut other than the obvious differences. I can't offer the benefits of one over the other. As for the one that makes flames, just think about it. If you cut the fuel, do you think you'll make sparks?? I would have to imagine an ignition cut would cause the flames...don't quote me though. I let my tuner do the dirty work here
Old Feb 26, 2009 | 05:55 PM
bossm's Avatar
seems to me that i need to get some slicks and dump that bitch as high as i can i hope i dont snap a axle.????????lol
Old Dec 4, 2011 | 11:16 PM
spiffy_civic's Avatar
Me 91 ef i launchd at 3.5 on VX wheels with decent street tires and it was almost perfect launch everytime also depends on driver's ability to handle traction and other variable's.. I am setting my 92 EG at 3,500 so i get that good launch also have VX Wheels still with same tires sry this post is old but i seen it so i thought id give a little of my 0.02
turboLScrx
Engine Management and Tuning
Nov 5, 2018 02:19 PM
reyesb25
Jun 9, 2013 07:01 PM
Records
24
Jul 12, 2012 09:27 AM
turbodailydan
Apr 28, 2010 08:28 PM
93FastLs
Nov 2, 2004 07:16 PM
