engine misfire code 71-74
i got these 2 codes and code 5 (map sensor) on a 96 civic dx, what could be the cause? its running like **** and i put new plugs, cap rotor and distributor, didnt change a thing... i let i t run for a while and plugs of cyl 1 and 2 where clean like new out of the box new and cyl 3 and 4 where black ritch.... any ideas?
ithink u might need to check an injector, swap out a #1 and #4 to num ber 2,3 if the engine give u code 72,73 and still miss u know what is the problem ...code 5 map sensor, check if u have any vaccum source go trough and see is been disconected, if not check voltage supply to sensor , chrck for good ground and i dentify if is a good parts..............and check for your timing c if it out ...and how bout compression
Thailand auto service
9WON4
Apr 22, 2004 05:38 PM
