Head job and Block job
do it yourself if thats all your going to have done.. pull the crank send to a machine shop to have it checked. buy bearing and rings some one around your area wouldn't charge u that much..
As long as your using stock bore size pistons you should be good. Probably wouldn't hurt to have your head checked at a machine shop for warpage and if so have it decked while its off now so you can get a good seal with the new head gasket, instead of a month down the road having to tear the head off again cause of a leaking HG. Napa and places like that will check your head and deck them if need be for fairly cheap
ya get it weighted and balanced.The machine shop I brought my engine to charged me $150 for weighting and balancing the whole bottom end. Had it balanced to 10k.
