ls/vtec compression psi
Old Feb 25, 2009 | 07:59 AM
sirt_eg's Avatar
Default ls/vtec compression psi
tested the ls/vtec I just got and it came out to be 215/215/210/210, Is that a fair compression for the ls/vtec with p73 pistons? I didn't built it but my buddie did and it had a bad valve and he gave it to me if I can fix it. Got it fix.
Only specs I know about it
b18a1 block
pr4 rod
p73 pistons
golden eagle ls/vtec kit
b16a2 head
supertech valve/springs
brian crower retainers
stock b16 cams/gear
Old Feb 25, 2009 | 08:04 AM
P12 EG6's Avatar
Default Re: ls/vtec compression psi
yes. that seems ok. did you do it warm and with the throttle wide open? and those numbers arn't bad,
Old Feb 25, 2009 | 08:07 AM
sirt_eg's Avatar
yea I did it with the car warm and at WOT. Also I'm guessing everyone suggest the 7 intake and 9 exhaust valve adjustment? factory specs at 6/7 but seems like everyone say 7/9 is the best choice for ls/vtec
imissmyfc3s
11
May 22, 2005 06:10 PM
torr
Feb 3, 2003 04:22 AM
Desperado
Jan 24, 2003 11:28 AM
