seat belts
Old Feb 25, 2009 | 09:01 PM
IP RACING's Avatar
Default seat belts
my seat belts retract super slow. sometimes not at all they just hang there. is there any way to fix this
Old Feb 25, 2009 | 11:25 PM
trustdestruction's Avatar
Default Re: seat belts
Seatbelts have a lifetime warrantee by Honda.
If you take it to the Honda dealer they will make you an appointment for them to do a cleaning of the seatbelt mechanism free of charge. If this doesn't work (which it likely won't), they will make you another appointment and order you new seat belts. They will replace them free of charge.
I had both seat belts on my del Sol replaced for free. The invoice said it would have cost me $370 if they hadn't had a warrantee. Now my seat belts hold me in my seat really good around corners, and of course they retract by themselves finally when I get out of the car.
Enjoy your new seat belts!
Old Feb 26, 2009 | 05:13 AM
honda.lioness's Avatar
Originally Posted by trustdestruction
Seatbelts have a lifetime warrantee by Honda. I had both seat belts on my del Sol replaced for free.
x2. My all stock 91 Civic's failed in 2001. Dealer fixed it no charge. The lifetime warranty is very clear in the warranty booklet. I am not sure this transfers to 2nd owners or cars with any kind of modification, though.
Old Feb 26, 2009 | 05:53 AM
IP RACING's Avatar
well my car isnt modified besides an intake. Does any one have a definite answer about 2nd or 3rd owners.??? Id love to get these fixed.
Old Feb 26, 2009 | 05:57 AM
Kuniva's Avatar
If a used car is bought with no seat belts does the warranty still apply? Will Honda replace them?
Old Feb 26, 2009 | 06:16 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
take the panel off that covers the seatbelt mechanism. I was having a similar problem with mine and once i took panels off to re-do my interior, i noticed that the bolt that holds in bottom mechanism was very loose! no good. but i bolted it back down and it re-tracts great. no problems at all.
check it out
American.Graffiti's Avatar
I never knew that honda seatbelts carried a lifetime warranty.
Old Feb 26, 2009 | 06:49 AM
It does.
No need to take it apart and check it out, just call them up and they'll do it all for you. I'm a DIY kinda guy myself but if the Honda dealership wants to do free work, i'll let them. The chances of those bolts coming loose on their own are very unlikely. I'm surprised this happened to you, DC2-ProdUcTiOnS.
Kuniva, I would think so. I think the warranty is on the belts. As long as they're Honda seat belts, they should have a warranty no matter if they're original to your car or not.
As long as they are the correct part number for your car, I think they will replace them.
Old Feb 26, 2009 | 08:15 AM
ajason24's Avatar
dont use em
or look for a bad fuse or just go to a junkyard and replace them
Old Feb 26, 2009 | 08:24 AM
commotion's Avatar
Originally Posted by ajason24
dont use em
huh?
Old Feb 26, 2009 | 08:48 AM
arrocha87's Avatar
damn im going to take mine too. they hold fine but they do retract real slow, like you have to push them up.
Old Feb 26, 2009 | 09:31 AM
ej1bmx's Avatar
Same here in my DD. I just dont care enough to have them fixed, so its whatever.
Old Feb 26, 2009 | 02:38 PM
dont use em
lolwut
Old Feb 26, 2009 | 10:39 PM
IP RACING's Avatar
Ill give the stealership a call on monday and find out for sure whats the deal on the warranty. Ill then let you guys know
Old Feb 26, 2009 | 10:42 PM
Davus's Avatar
dont use em
How do I seatbelt fuse? I understand the first things to do when there's a problem is check fuses for one, but I think this is the exception!
TakeCarDaddy
Honda Civic (2006 - 2015)
Oct 25, 2018 10:16 AM
petrez
Aug 12, 2018 06:42 PM
massakalis56
Sep 16, 2017 12:41 PM
new2ahonda
Honda CR-V & Element
Aug 18, 2012 02:02 PM
240MANSX
Dec 23, 2007 07:06 PM
