need HELP on trailing arms????
Old Feb 24, 2009 | 11:50 AM
Civic-Kids's Avatar
Icon2 need HELP on trailing arms????
not sure wat it called... is it a trailing arms???
i just wanna know how can i take out the broken screw n put a new one in?
do i need a tool for this? if so can i have a picture...
Old Feb 24, 2009 | 12:10 PM
instructor74's Avatar
Default Re: need HELP on trailing arms????
That is not the trailing arm. It is the front hub assy and what is broken is the wheel stud. You need to press out the hub assy and have the stud pressed out and a new on installed
Old Feb 24, 2009 | 12:46 PM
Civic-Kids's Avatar
how can i press out the hub assy?? any tool?
Old Feb 24, 2009 | 12:53 PM
rudebwoy's Avatar
2 ways.
way #1 put it back on the car rent a slide hammer tool and puller attachment from autozone. pull the spindle reinstall carefully using the axle nut to pull it in.
way#2 use a big socket hammer it out from the inside replace the stud, its gonna take some skills to put it back together without damaging the bearings. good luck.
Old Feb 24, 2009 | 12:58 PM
or since it is already off the car take it to a service shop with a press and have the hub pressed out and the stud changed and pressed back together. It shouldn't take more the an hour. most places around here would do that for under $50. I would call honda and get all 4 studs and change them at the same time
Old Feb 24, 2009 | 01:23 PM
Civic-Kids's Avatar
o ok.. thx bro... i learn alot. :D
spectastic
Honda Civic (2001 - 2005)
Feb 17, 2013 03:24 PM
imadigitalgod
Jun 9, 2010 01:54 PM
elrandeeto
10
Apr 29, 2006 12:07 PM
ivanson
Jun 29, 2005 06:53 PM
slowassR
Apr 30, 2003 01:44 PM
