WTF is a P30...
Now to my hatch...Changed turbos...Went on a cruise came back and right in driveway did a rough idle...C/E came on..Code 9..Crank position sensor...Rebuilt dizzy..Put it on and same trhing rough idle but no C/E light..Now it wont turn on.There is spark...I think I fried my ECU...Everything is wired and plugs are hooked up right...So any input would be appreciated ...Thanks..
Are you talking about your buddys B16 or your hatch?
You're saying that your turbo hatch isn't starting. You have spark. Somehow you figure your ecu is fried. What other tests have you done? What did you do before it stopped starting? You rebuilt your distributor? Are your injectors firing? Is your fuel pump priming when you turn your key? Are your plugs fouled?
More info is definitely needed.
charjacq
Aug 5, 2002 10:54 AM
