EH3 D16Z6 harness = EG6 B16A harness?
I have a 1994 Si and am swaping in a B16A SiRII (S4C LSD
) swap and I tell you guys, I can't wait I've been wanting to have a 92-95 Si wth a B16 since I was 12 kid you not.
Anyways, sounds like the only thing I need is to wire the knock sensor?
) swap and I tell you guys, I can't wait I've been wanting to have a 92-95 Si wth a B16 since I was 12 kid you not.Anyways, sounds like the only thing I need is to wire the knock sensor?
Assuming you are using the P30 ECU (stock B16A), all you need to do is lengthen a few wires and run a knock sensor wire.
I did this swap 8 years ago and I liked it.
i also believe you will have to extend the o2 sensor wires due to the location being down at the bottom tube of the header but that should be it as far as wiring goes when you use your harness.
hughesl
Aug 7, 2003 05:11 PM
LD_EGSICK
20
Feb 4, 2003 07:47 PM
JunCivic Hatch
Oct 22, 2001 04:48 AM
The wiring for the IAT sensor needs to be lengthened, I think that may be the only thing that needs to be extended actually.
