New PCM(Used) giving me code P0700 & P1768
Old Feb 25, 2009 | 08:42 PM
hondaboi7's Avatar
Default New PCM(Used) giving me code P0700 & P1768
My old PCM in my 98 Civic Ex died out(smoked) so i bought a used one online and now its giving me P0700 and P1768 both relating to transmission. I never had any problem with the transmission until i got the new pcm. I've tried resetting the pcm by removing the 7.5amp(back-up) fuse under the hood and also disconnecting the battery for 5 mins. Also, clearing the codes does nothing, they just come back. Any help would be nice. thanks
Old Feb 25, 2009 | 11:29 PM
trustdestruction's Avatar
Default Re: New PCM(Used) giving me code P0700 & P1768
Sounds like you put an automatic ECU into a manual car.
Do you have a manual transmission?
What are the last 3 digits on the ECU's label? (label starts with 32870 or something like that)
Old Feb 26, 2009 | 05:24 AM
hondaboi7's Avatar
my car is auto. the pcm is for a 98 civic ex auto too. the numbers are, 37820-p2p-a84-273
the old one starts with the same numbers too.
Old Feb 26, 2009 | 07:05 AM
hmm, not sure then, the ECU is the proper one.
blacktibby07
Mar 7, 2011 04:16 PM
z6htch
13
Nov 25, 2008 02:44 AM
taejin11
May 28, 2004 05:52 AM
your username here
Nov 29, 2003 04:58 PM
JChops
Oct 9, 2003 06:53 PM
