Cusco Front Upper Tower bar question.
Old Feb 23, 2009 | 05:25 PM
95sloweg's Avatar
Default Cusco Front Upper Tower bar question.
I just got my cusco tower bar for my 1995 civic. it obviously wont go on. i will call tomorrow the company i ordered this from because they are currently closed for the day. the ends on the bar will not bolt up to my shock tower bolts. i am pretty sure that this part is wrong. i thought the ends are supposed to be either a full circle or half of one instead of this. if any one has this part please tell me whether it is the wrong part or how to get it to bolt up.
The driver side end sticks too far just like this end.
Old Feb 23, 2009 | 06:39 PM
robear78's Avatar
Default Re: Cusco Front Upper Tower bar question.
It will fit, but made for a Type-R or Civic Si 99-00
You need to get 2 studs on each side, that are normally there on a DC2 Type-R or EM1, but not there obviously on any EX, DX, or LX, LS, GSR
It is VERY EASY to install, and most def worth the effort.
I had a Billet NEUSPEED Bar with the same mounting points on my 00 SI :thumbsup:
Old Feb 23, 2009 | 07:19 PM
dohcdelsol's Avatar
mis-info
my 92 hatch had the holes with oem gromets inplace. same with my 95 coupe.
that bar would fit any integra, doesnt have to be a type-r. its the same thing as the gsr bar basically.
OP: check if you ahve the holes there. if you do pop the gromet out and use a nut bolt combo. if you dont, put the bar in place, mark with a sharpy the holes and a quick drill and nut bolt combo. should take you 5 minutes. make sure the bar is facing the right way.
Old Feb 23, 2009 | 07:34 PM
95sloweg's Avatar
thanks for the info. i think i know what gromet your talking about. ill check tomorrow when i get off of work to see if those holes/gromets are in place. its dark and pretty cold out right now.
Old Feb 24, 2009 | 03:07 PM
95sloweg's Avatar
just spoke with the company that i ordered the bar from. i sent them pics and they are going to get in contact with cusco to find out if that is actually the right product or if it was mis labled. but if it is the right tower bar it looks like i would have to drill inside the black box of this pic...
Old Feb 26, 2009 | 02:04 PM
95sloweg's Avatar
just got off the phone with the company. they talked to cusco and showed them the pics. they said that i have to drill the holes to mount it and the bar is also backwards in the pics.
LaosGuySi
Apr 25, 2007 11:03 PM
DC2 Mang
Jul 22, 2006 08:42 PM
duneracer69
Feb 6, 2006 11:38 AM
erasable180
Nov 24, 2005 06:17 PM
stareatsun
Feb 18, 2004 06:46 AM
