radiator fan not turning on....what to check?
Old Feb 24, 2009 | 03:07 PM
hotcivicsi's Avatar
Default radiator fan not turning on....what to check?
98 civic w/ 98 LS B18B1
no A/C
Just realized today my fan doesn't come on when the engine warms up. I was sitting in traffic and my temp gauge was rising past half way, it got about almost 3/4 of the way up and I shut the car off. One I start moving everything is fine, stays constant at about 1/4 way. I just got the car recently so I'm guessing its never worked since I got it.
Let me know what to check
Thanks ahead of time
Old Feb 24, 2009 | 03:15 PM
quilksilver's Avatar
Default Re: radiator fan not turning on....what to check?
check your fan switch and make sure you have enough coolant
Old Feb 24, 2009 | 10:42 PM
godluvstegs's Avatar
you might want to check you thermostat.. it cost like 15 bucks for a new one.. if that doesnt work then it might be your connection to fan or check the the coolant temperature sensor.. but first try the thermostat make sure to drain the coolant first when the car is cold.
Old Feb 25, 2009 | 05:05 AM
hotcivicsi's Avatar
just realized today my lower radiator hose is still cool after drivng to work....Seems like the thermostat is stuck closed...going to replace that when I do the timing belt
kustom_2323
Sep 24, 2009 08:15 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
SpoonREVS
Jan 24, 2006 05:42 PM
KB96VTEC
May 23, 2005 06:30 PM
quickLSt
Jul 6, 2001 09:29 PM
