Exhaust Problems. HELP!
I ordered an Apexi Worldsport 2 for my b-swapped 93 civic dx. It's my third Honda but first swapped one, so not thinking about it I ordered the exhaust for the 93 hatch. The manifold doesnt like up right, should I have ordered one for a 95 integra. I tried to make it work by cutting off the flange and welding an extension on, with with the manifold slightly to the left, I'm having a lot of trouble Making it work. Thanks
you usually do need to extend the pipe some and how slight to the left are we talking cause there was another guy and his header and exhaust were side by side really off if its within the 1 to 2 inch range you can usually just force the exhaust pipe but another thing to check is that the s bent pipe the last section before the axle back is on correct it will go on both ways but it will throw the alignment of the exhaust off and also make it sit a little higher then it should i had that problem before. hope this helps
egg_baLLa
Dec 28, 2005 10:48 AM
deadeyehatch
Mar 18, 2004 08:24 PM
