I do not get the right idle..
Old Feb 25, 2009 | 06:29 PM
sorullo's Avatar
Icon6 I do not get the right idle..
own 93 del sol si 1.6 sohc vtec, and i bought it from a lady that does not knows how to drive stick tranny..but this car has a automatic ECU (((of course it has the check engine light on))) now when i boght it that car was just fine and i drove it for a year.. now after the year and something of days the engine started to lose the idle. and since then, i never get the right idle, the rev goes up to 3 and then down to 1 in about a second....but the engine does not go off.. it keeps on,.. and everything else is ok but never get the right idle. BUT.. yes i said BUT i notice that sometimes the engine get it right.. yes i suddenly gets steady , but most of the time when i make a stop the idle goes back unsteady and since then i got used to drive it like that, but that unsteady sounds is annoying..
some of my friends said that is my throttle sensor.. but that FR$$# sensor is like welded to the throttle, there is not screw on it.. should i replace the whole throttle body instead?
any advice welcome!!
Old Feb 25, 2009 | 06:32 PM
94EGKUSH's Avatar
Default Re: I do not get the right idle..
Clean your IACV!
Search and you will find it!
Old Feb 25, 2009 | 06:44 PM
bossm's Avatar
Originally Posted by 94EGKUSH
Clean your IACV!
yea sounds like iacv most likely
bossm's Avatar
Clean your IACV!
and also check for a vaccum leak
Old Feb 25, 2009 | 06:53 PM
joelmatt89's Avatar
these should help
IACV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
FITV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
scooter2525
13
Dec 30, 2013 05:23 AM
96hatchBoy
Sep 18, 2012 03:45 AM
cdx280
Sep 1, 2005 08:45 PM
obsidianG35
Oct 1, 2004 09:47 PM
Vp Special K
Apr 4, 2003 09:14 PM
