ek side skirts on a eg
hi guys and ladies i just picked up a 92 vx hatch and have big plans for it (incoming build thread) and was wondering if ek sides bolt up to the eg or is there alot of work that needs to go into it pls help . 1st post so if this is wrong spot pls give a heads up for better spot
I think they need cut, there are probably a few threads on this and probably a DIY i'll see what i can find. oh and dont worry your in the right spot for this post.
Edit: Found it
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ek-sides-eg-how-142946/
Edit: Found it
For hatches, approximately 4" needs to be trimmed from the front. Most, if not all, of the clips do not line up, so you will need to drill holes into the lower rocker panel. Also, to make it a cleaner look, you will have to run mud guards or do some 'body' work on the side skirt to cap the front end you cut off.
/thread.
/thread.
/thread.
/thread.
I have EK 4dr skirts I tried fitting on my EG 4dr, and the EK flares out at the bottom of the fender where the EG doesn't and leaves a odd looking gap. No go for me.
yeah, a little cutting is due, but i think its worth it. They look really good in conjunction with a front lip and maybe some mud flaps to finish it off, also the mud flaps hide the cut on the front of the skirt. i got these on my EG and they look pretty good. i just had to drill a few holes in the front due to the clips not matching up, but some of the clips in the back matched perfect. Here are some pics of mine, i don't have the lips back on yet, and the car freakin dirty because it's in the paint shop, but I think they look great.
wow thanks for the pics car looks gr8 and thanks all for the posting with help will be getting on this sooner than later . I"ll also have pics coming of my start just need time
From the pics they look 10 times better than the eg skirts so im kinda siked ,why u wanna take yours off btw ?
i want to take mine off because im going full type r with my eg. type r lips/sides, paint, etc. but im broke now.. so obviously ek sides are going to be on.. they look pretty clean though. you can see them on my myspace.. myspace.com/performs
bartek_b
Jan 2, 2003 09:52 PM
