tranny problem
Old Feb 24, 2009 | 11:52 PM
mxracer420's Avatar
Default tranny problem
i got a d16y8 and i pulled it out of my dads car which it started making a grindign noise when clutch was out so we replaced the clutch surfaced flywheel etc. replaced the throwout bearing everything and then i put it in my hatch and about 40 miles of driving it started doing the same grinding as if throwout bearing is already bad. any ideas why it would go through a throwout so bad?
Old Feb 25, 2009 | 06:20 AM
94EG8's Avatar
Seagull Management
Default Re: tranny problem
When does it grind? If the clutch pedal is depressed when it grinds its the throwout/release bearing. If its grinding when the clutch pedal is up (IE clutch engaged) then the transmission input shaft/mainshaft bearing is bad.
Old Feb 25, 2009 | 09:51 AM
mxracer420's Avatar
it grinds when it is depressed example idlinf and like i know its the throwout but i literall replaced it 100 miles ago y would it go bad so quickly?
Old Feb 25, 2009 | 12:30 PM
94EG8's Avatar
Seagull Management
Possibly contaminated with dirt/sand if the flywheel inspection plate was missing. It also possible the bearing was just bad out of the box.
Egreyes
Apr 15, 2009 05:05 AM
NosCivic01
Apr 25, 2006 03:37 PM
doublejz
Mar 9, 2004 01:19 PM
AzntaggeR
Feb 18, 2003 06:01 PM
