im having some trouble with my axles
Old Feb 23, 2009 | 05:21 PM
92 hatchback's Avatar
Default im having some trouble with my axles
well i have been trying to get my axles off but they wont come off and i was wondering if anyone else had some suggustion
Old Feb 23, 2009 | 06:40 PM
98civdx's Avatar
Master Detailer
Default Re: im having some trouble with my axles
pry bar in the end by tranny and pull.
this happens alot.
Old Feb 23, 2009 | 07:05 PM
Former User's Avatar
Or are you saying you are having problems popping out the ball joints?
Old Feb 24, 2009 | 08:00 AM
i have been try to get the 32 nut of the axles but wont come off
Old Feb 24, 2009 | 09:28 AM
Answer: Long breaker bar, PB blaster, and someone to hold the brake pedal down.
Old Feb 24, 2009 | 09:48 AM
thumper64's Avatar
Unstake the nut, and with the wheel still on the car and vehicle on the ground, use a breaker bar and a pipe to get leverage. I only weight 145lbs or so, and I got mine off no problem doing this.
Old Feb 24, 2009 | 09:53 AM
DumpedSi's Avatar
if you have air that works the best if not stick a screwdrive in the rotor against the caliper to keep the rotor from spinning then use a breaker bar ( jack handle ) for leverage.
Old Feb 24, 2009 | 10:14 AM
MrRabbit87's Avatar
air gun or electric impact gun. Everything else is a pain, but yeah if no impact tools, use the long as breaker bar gl ... its a painnn
Old Feb 24, 2009 | 11:22 AM
Pothole987's Avatar
leave tire on, ( steelie) put e brake on while car is on ground, then use the 32mm with a breaker bar, and put an extension on the end of the breaker bar. also, heat may be your friend.
Old Feb 24, 2009 | 08:47 PM
yeah i bought the long beaker bar i could find and i have the e bake up and im a pretty strong guy and every time i try im pick up the car and i have broke so many wrench
Old Feb 24, 2009 | 10:40 PM
EK9r!der's Avatar
i had the same problem trying to take of the passenger side on my friends gsr.
your best option will be to use an impact gun.
Old Feb 25, 2009 | 04:13 AM
ziggy3784's Avatar
x2 on the impact gun. I just changed my passenger side axle last week and didn't even break a sweat using my electric imapct gun.
Old Feb 25, 2009 | 04:59 AM
iliv2xlr8's Avatar
I broke a 1/2 inch Craftsman breaker bar on one of mine..... It happens. Electric impact should take care of it.
93JDM_H22
Jun 19, 2010 01:23 AM
cwhabegger
May 17, 2010 12:48 PM
taking-back-sunday07
27
Feb 22, 2007 08:10 PM
tonesdef
Jul 12, 2003 02:33 PM
EG1834
20
May 15, 2003 12:04 PM
