new clutch question
Old Feb 26, 2009 | 04:12 AM
TurboPWR4's Avatar
Default new clutch question
im looking for a new clutch i dont know which one to get..... its a 1992 honda civic si. it is my daily driver i don't want a stock clutch but i dont want anything high performance either just something reliable .. what kind of clutch do you guys recommend? thanks.
Old Feb 26, 2009 | 04:47 AM
bigD's Avatar
Default Re: new clutch question
exedy oem replacement
Old Feb 26, 2009 | 05:06 AM
instructor74's Avatar
I like a stage 1 style of clutch a little higher grip then stock a slight increase in pressure plate spring rate giving a better pedal feel. Go with what ever brand you like just get the next step up from stock.
Old Feb 26, 2009 | 10:40 AM
goldrushsi's Avatar
ACT all the way!
Old Feb 26, 2009 | 10:42 AM
goldrushsi's Avatar
Check out the act website. There is a chart that you can make a combination of pressure plate and disc so you can get the results you're looking for.
Old Feb 26, 2009 | 10:44 AM
EK9r!der's Avatar
x2!!! they are responsive, but not too aggressive.
Old Feb 26, 2009 | 10:45 AM
D16SohcVtec's Avatar
If it's just a daily, why not just go to your local parts store and get a clutch kit for around $125 or so? My buddy has been running a local parts clutch on 12 psi of boost from a greddy kit for 2 years and no problem.
Old Feb 26, 2009 | 12:13 PM
TurboPWR4's Avatar
i want to go with a stage 1 exedy clutch and i was wondering if i should resurface the oem flywheel or get a brand new light flywheel to go with the clutch kit?
Old Feb 26, 2009 | 01:08 PM
brutekiller787's Avatar
if you plan to go boost, keep your stock flywheel, helps your rpms stay higher so you can stay in boost longer.
Old Feb 26, 2009 | 01:29 PM
P12 EG6's Avatar
id resurface the flywheel and get a compition clutch stage 1, perfect for what you want. and you wont have to drive around like your working on a calf machine at a gym, stock pedal feel
Old Feb 26, 2009 | 06:33 PM
Jimster480's Avatar
ya get a stage 1 or OEM replacement. I have a stage 3 6 puck sprung clutch in my DD and its a BITCH
Old Feb 26, 2009 | 06:50 PM
TurboPWR4's Avatar
BOOST maybe later...
Old Feb 26, 2009 | 06:51 PM
TurboPWR4's Avatar
What do these compition clutches go for and they tell me that the exedy clutches are the oem replacement...
Basilias
May 25, 2010 12:34 PM
CO_CReX
Jun 22, 2007 05:37 PM
omg_miiiike
Aug 1, 2005 01:47 PM
Perfourmance
Jun 2, 2005 02:50 PM
streetlvlhatch
Jan 14, 2004 07:47 PM
