**high preasure in system**
Old Feb 25, 2009 | 06:06 PM
krysted9354's Avatar
Default **high preasure in system**
ok my i rebuild my enigne, new water pump, etc, and the .5" radiator, o noticed my preasure is very high, almost my hose came off, what could be problem ?? mabey thermostat ?
Old Feb 25, 2009 | 07:04 PM
CA6VTEC's Avatar
Default Re: **high preasure in system**
Air Build up in the system.. Easy. Remove the rad cap, turn on car and let it warm up until the fans turn on.
Old Feb 26, 2009 | 12:43 PM
ok, so what would be happening if the thermostat would get stuck or not open or stay open ? i just want to make sure my thermostat if fine,
because the radiator hose side housing if from a 92-95 and the water pipe is from a 88-91 because of the thermo fan switch, so but ill try that,
also my fan doesnt go on till like 10-15 minutes whats up with that ?
Old Feb 26, 2009 | 01:05 PM
bump
Old Feb 26, 2009 | 01:58 PM
P12 EG6's Avatar
well, does it run fine??? or does it overheat, if the thermostat was stuck closed the car would overheat, check to see if boath hoses heat up, and i agree pull the cap and bleed out the air.
Old Feb 26, 2009 | 02:50 PM
heat wise its fine, but the hoses take like 15 minutes to heat up, also its all new re built 200 miles ago so i m stil braking it in,
but so what cap off , start it and run it and it iwll bleed it self ? as i unscrewed the bleeder bolt when car running and no air came out ?
also what kg radiator cap is recomended is 0.9 to small preasure ?
also will location of the reservoir tank matter ? can i be to high ?
Old Feb 26, 2009 | 04:01 PM
ttt
b18cEggie
Feb 16, 2012 10:14 AM
TurboTeG4
12
Dec 27, 2009 10:20 AM
supermotothud
Dec 19, 2008 01:38 AM
yz125rider21
11
Aug 9, 2006 04:42 PM
PreIudeSI
Aug 24, 2004 09:55 PM
