Question about rear disc conversion on 97 civic coupe
Old Oct 12, 2005 | 07:32 PM
PhatBoy5015's Avatar
Default Question about rear disc conversion on 97 civic coupe
i was wondering if it was necessary to get new trailing arms to convert your rear drum to disc. Because i was looking at the hub assembly in the back when i changed my brake shoes and it looks pretty much the same as the disc brake hub assembly. Is there not a way that i could remove all the drum hardware and replace it with the bracket for the caliper?
Old Oct 12, 2005 | 07:36 PM
Targa250R's Avatar
be professional
Default Re: Question about rear disc conversion on 97 civic coupe (PhatBoy5015)
The trailing arms are the same. The difference is the hub assembly. You can bolt disc brake hub assemblies onto your stock trailing arms. You'll need the proper Torx bit though.
Old Oct 12, 2005 | 07:52 PM
EL Vap133's Avatar
Can you easily and affordibly get all the necessary parts you need to do this?
Old Oct 12, 2005 | 09:04 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Question about rear disc conversion on 97 civic coupe (EL Vap133)
can u use 90-93 teg rears?
boostitalready
Nov 25, 2012 04:36 PM
terror_storm
117
Mar 20, 2012 07:46 PM
d-series guy
10
Jan 1, 2009 08:01 AM
vtec-adykt
Jan 27, 2005 07:13 PM
MugenHonda
Jun 12, 2003 05:14 PM
