Y7 head on B8 block.. which timing belt?
Old Oct 13, 2005 | 05:06 AM
VTC_CiViC's Avatar
Default Y7 head on B8 block.. which timing belt?
I thought I had asked this but I can't seem to find my thread anywhere, so i'll try again..
I'm wrapping up a friend's car, I swapped an old Y7 head I had laying around onto his '94 CX hatch. I've got everything on and done except I noticed the D15B8 timing belt now has a tremendous amont of slack with the Y7 head on (using the B8 cam gear), something tells me I'm supposed to use a different t-belt or water pump or something. Anybody know what the missing link is?
Old Oct 13, 2005 | 06:42 AM
drtyhatch's Avatar
Default Re: Y7 head on B8 block.. which timing belt? (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">I thought I had asked this but I can't seem to find my thread anywhere, so i'll try again..
I'm wrapping up a friend's car, I swapped an old Y7 head I had laying around onto his '94 CX hatch. I've got everything on and done except I noticed the D15B8 timing belt now has a tremendous amont of slack with the Y7 head on (using the B8 cam gear), something tells me I'm supposed to use a different t-belt or water pump or something. Anybody know what the missing link is?</TD></TR></TABLE>
umm can you use a y7 head on a cx block, i thought the cx pistons were set up for 8 valve. Is the Y7 8valve too. to be honest with you i would think you should use they Y7 cam pulley and the b8 belt. i don't know this is a weird set up.
Old Oct 13, 2005 | 08:31 AM
VWVORTEX's Avatar
Default Re: Y7 head on B8 block.. which timing belt? (drtyhatch)
y7 is 16, yea... this sounds very half assed..
Old Oct 13, 2005 | 09:10 AM
VTC_CiViC's Avatar
Default Re: Y7 head on B8 block.. which timing belt? (GripStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GripStar &raquo;</TD></TR><TR><TD CLASS="quote">y7 is 16, yea... this sounds very half assed..</TD></TR></TABLE>
What makes this half-assed? Here's a little 'Did you know?' kids: Many if not most D15B8's (like this one) came with 16v pistons (B7's) in order to save production costs.
Now that we got that out of the way, does anybody here have a useful answer?
Old Oct 13, 2005 | 09:20 AM
huntarrr's Avatar
I always thought you were supposed to use the same timing belt as the head?
Old Oct 13, 2005 | 10:38 AM
VTC_CiViC's Avatar
Default Re: Y7 head on B8 block.. which timing belt? (vsm98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">I always thought you were supposed to use the same timing belt as the head?</TD></TR></TABLE>
Is that so? I guess I'll try the Y7 belt, thanks
Old Oct 13, 2005 | 11:38 AM
nsxmatt's Avatar
Y7 is the same height as the Y8 right? A VX belt might work?
Old Oct 13, 2005 | 12:26 PM
FalkenSiR's Avatar
Default Re: Y7 head on B8 block.. which timing belt? (nsxmatt)
Since a y7 is a 1.6 the timing belt most likely will be off on the b8 1.5 block. Now if you use the belt they use for mini-me's, that could work, but don't quote me, get more opinions first...
Old Oct 13, 2005 | 01:00 PM
Burke's Avatar
Banned
Default Re: Y7 head on B8 block.. which timing belt? (fast88std)
up cause i am about to put a y7 head on a b7 block
Old Oct 13, 2005 | 08:51 PM
Burke's Avatar
Banned
up
Old Oct 13, 2005 | 09:29 PM
VTC_CiViC's Avatar
Default Re: Y7 head on B8 block.. which timing belt? (Burke)
Well I just used the Y7 T-belt (which was the same length as the B8 btw), Y7 cam gear and Y7 crank snout (not neccesary, I just did it because it has a casted belt guard lip vs. the loose thin metal disc the B8 uses on both sides of the snout), everything lines up perfect, motor is on time properly. Tomorrow I crank down the head and start 'er up
Old Oct 14, 2005 | 04:22 AM
Burke's Avatar
Banned
thanks for teh heads up!
Old Oct 14, 2005 | 05:59 AM
drtyhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Well I just used the Y7 T-belt (which was the same length as the B8 btw), Y7 cam gear and Y7 crank snout (not neccesary, I just did it because it has a casted belt guard lip vs. the loose thin metal disc the B8 uses on both sides of the snout), everything lines up perfect, motor is on time properly. Tomorrow I crank down the head and start 'er up </TD></TR></TABLE>
huh well thats cool, i guess my educated guess was correct. for figuring it out.
Old Oct 14, 2005 | 02:41 PM
VTC_CiViC's Avatar
Just a quick 411 for anybody esle interested, the car started and runs like a champ
Old Oct 14, 2005 | 02:52 PM
Bense's Avatar
i recently put a b7 head on my b8 block, and i also had b7 pistons in my block
Old Apr 5, 2015 | 07:06 AM
Dmrmonchichi's Avatar
See I did this swap backwards, got a 95 d15b8 head onto a 98 d16y7 block. Can't seem to get it timed right. What do I do? Only thing that is not y7 is the head and timing belt. Gears, distributor, etc... Are all y7.
egcivic
Nov 7, 2007 01:35 PM
yrulkn@me
Jul 2, 2007 01:08 AM
hatchback19
Feb 29, 2004 10:56 AM
civicracer1993
Jan 12, 2003 08:53 PM
