TURN SIGNALS, SPEDOMETER, TEMP RPM AND GAS GAUGES, HAVE DUENCED!!!
Old Oct 12, 2005 | 08:16 PM
eternaljihad's Avatar
Default Someone Please Help
Just curious, all of a sudden my gauges and my turn signals as well as my reverse lights don't work. i've checked the wiring harness in the engine bay and everyting looks fine, oh and its an 93 ex coupe so i have a clock in my car and that's not on either, but my hazzards work, what the fU#% . this is very frustraiting, someone please help cuz gas is $3 and i have to put some in everytime i drive cuz the instrument panel doesnt work
Modified by eternaljihad at 3:24 PM 10/13/2005
Old Oct 12, 2005 | 10:12 PM
Default Re: TURN SIGNALS, SPEDOMETER, TEMP RPM AND GAS GAUGES, HAVE DUENCED!!! (eternaljihad)
so u mean that this has never happened to anyone????
Old Oct 13, 2005 | 10:32 AM
?no one has an answer?
Old Oct 13, 2005 | 02:35 PM
taney's Avatar
it's a 10amp fuse .. same thing happened to me .. you shorted something in the car .. look at the fuse cover .. it's the one that says backup light ..
Old Oct 13, 2005 | 02:38 PM
taney's Avatar
Default Re: (taney)
replace this fuse ..
Old Oct 13, 2005 | 02:41 PM
dogbiscuit's Avatar
hopefully he's checked the fuses already.
Old Oct 13, 2005 | 02:46 PM
taney's Avatar
i've had the same symptoms .. it could also be #15 in the engine fuse box .. but yeah .. i'm pretty sure the fuse is blown .. and it will blow instantly again when he puts in a new fuse if something is shorting and he doesn't know ..
Old Oct 13, 2005 | 02:48 PM
RedEK9's Avatar
Default Re: (taney)
Good looking out
Old Oct 13, 2005 | 02:50 PM
taney's Avatar
Default Re: (RedEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEK9 &raquo;</TD></TR><TR><TD CLASS="quote">Good looking out </TD></TR></TABLE>
Old Oct 13, 2005 | 03:39 PM
Dj^BaNNeD's Avatar
Hey....Im having the same problem you are, but my turn signal, hazzards, and brake lights work (when I brake).
Old Oct 15, 2005 | 04:17 PM
Default Re: (Dj^BaNNeD)
i really appreciate the help fellas, i'll check right now, but i did check all the fuses
Old Oct 15, 2005 | 04:38 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (eternaljihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eternaljihad &raquo;</TD></TR><TR><TD CLASS="quote">i really appreciate the help fellas, i'll check right now, but i did check all the fuses</TD></TR></TABLE>What's the verdict?
Old Oct 15, 2005 | 04:59 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eternaljihad &raquo;</TD></TR><TR><TD CLASS="quote">?no one has an answer? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eternaljihad &raquo;</TD></TR><TR><TD CLASS="quote">so u mean that this has never happened to anyone???? </TD></TR></TABLE>
please read the rules:"2.B. Please do not make thread titles in all caps or with symbols that will attract attention. This steers users away from the other (most likely more important) threads on the page"
as said above,it's most likely that fuse is blown.BUT,you need to find out why it blew.hopefully it won't blow after you replace it,but if it does,start troubleshooting.try removing the turn signal and reverse bulbs,then replace the fuse and see what happens.check the wiring in those areas to make sure nothing is pinched.
Chris
Old Oct 16, 2005 | 08:48 PM
taney's Avatar
to Chris .. i tried to tell these kids .. but they like to ask the question x2521652161 times ..
Old Oct 18, 2005 | 01:10 PM
Default Re: (taney)
it worked out fine its just that my left turn signal clicks a hell of a lot faster than my right turn signal, also my spedometer and climate control lights don't come on at night(or when i turn my lights on) than. though
Old Oct 18, 2005 | 01:25 PM
taney's Avatar
if the cluster works .. and the lights don't light up .. it could be the dimmer switch .. most likely .. one light kicks faster than the other .. you have a burned bulb .. making the relay go faster .. check it up and come back for more ..
Old Oct 19, 2005 | 11:09 AM
Default Re: (taney)
my dimmer switch is turned all the way up, or on. you know what i mean. my instrument panel is not oem its aftermarket but that shouldnt stop the climate control lights to come on, because i know the they are linked together somehow(ie. turn on the headlights the instrument and climate control panel lights up) but thanx for the info. i think the turnsignal does have a relay prob....bob
j3wman
Jun 1, 2012 05:31 PM
supamike3232
Sep 28, 2008 03:28 PM
EfSedanLove
Jun 13, 2008 06:46 PM
TurboGoKart
Aug 21, 2006 12:18 PM
Ej1_coupe
Sep 26, 2004 06:39 AM
