94 civic engine in a 92 civic
Old Oct 13, 2005 | 06:02 AM
bjr's Avatar
bjr
Default 94 civic engine in a 92 civic
Will a 1994 civic engine from a stick shift car fit in a 1992 civic stick shift? Will it just bolt in or will I have to change the electronics or something else? How about the transmission. are they the same? thanks Brian
Old Oct 13, 2005 | 06:12 AM
drtyhatch's Avatar
Default Re: 94 civic engine in a 92 civic (bjr)
please use the search feature.
but yeah it will bolt directly in.
Old Oct 13, 2005 | 06:13 AM
civexturbo's Avatar
Just swap it in. If the engine is the same it should be an easy swap. If you are going from non-vtec to vtec, you will need the proper ecu and wiring harness or modify your existing harness.
Old Oct 13, 2005 | 06:37 AM
streetracerof06's Avatar
Default Re: (civexturbo)
same wiring harness will work you would just have to run 3 wires off your VTEC solinoid, two to the new ECU (you will need the VTEC ECU) and one wire is a ground.
Old Oct 13, 2005 | 06:57 AM
bjr's Avatar
bjr
Default Re: 94 civic engine in a 92 civic (drtyhatch)
I did a search but am not up on all the abreviations and what they mean. Thank you for the reply and I will try to learn more . Brian
Nisif
Honda Civic (2001 - 2005)
Apr 30, 2024 08:03 PM
Bobbyboyd
Sep 17, 2016 01:35 AM
aznwash3wboi
Dec 22, 2008 02:23 PM
DACteg
Nov 6, 2008 08:02 AM
joestud
Sep 27, 2003 03:37 PM
