Spark Plug Question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">According to the manual for my CRX;
>>>13 lbs-ft</TD></TR></TABLE>
Or finger tight and then a 1/4 turn -1/2 turn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 »</TD></TR><TR><TD CLASS="quote">
Or finger tight and then a 1/4 turn -1/2 turn.</TD></TR></TABLE>
Good luck getting your fingers in there
Or finger tight and then a 1/4 turn -1/2 turn.</TD></TR></TABLE>Good luck getting your fingers in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loclowd »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> haha, I should have known. I meant to say get it to where it should be finger tight lol.
From: I told you to wait in the truck in Texas, United States
*NGK states for a 12mm plug in an aluminum head 10.8-14.5 lbs-ft.
{So 13ft-lbs is close enough...}
See:
http://www.ngksparkplugs.com/t...ry=US
See:
There is no way finger tight then 1/4 to 1/2 turn is going to be 10-13ft./lbs of torque. At least not on a brand new ngk. try finger tight then put a good torque wrench on it and take it to 10-13 lbs. , you will make 1.5- to 2.5 full turns on the plug because of the new washer on the plug.My friend blew a plug out of his cobra doing that 1/4 turn method.
The Weather Man
Feb 10, 2006 06:10 AM
