Engine that hasnt been started for a year.
Is there going to be any problems with not starting the engine for a year. Is there anything i can do to make sure everything is lube up and ready to start up. I'm just worried that i might spin a bearing with an engine that hasnt been running for one year because the crank might not be lube up with oil. Or is the engine is going to be fine?
Change the oil first...Then pull the ecu fuse and crank it for a few seconds to build oil pressure. Then put you ecu fuse back in. Then replace the gas. You should be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisColeman »</TD></TR><TR><TD CLASS="quote">Change the oil first...Then pull the ecu fuse and crank it for a few seconds to build oil pressure. Then put you ecu fuse back in. Then replace the gas. You should be good.</TD></TR></TABLE>
how do you replace the gas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 coupe »</TD></TR><TR><TD CLASS="quote">
how do you replace the gas?</TD></TR></TABLE>
there should be a drain plug on the bottom of your gas tank.
kikoman
Jul 13, 2009 08:40 AM
Rod.
Jul 18, 2005 09:16 PM
IloveNewt
Mar 18, 2004 11:21 PM
