LS into 98 coupe
Old Oct 13, 2005 | 02:58 PM
b_serious's Avatar
Default LS into 98 coupe
i think my idle air control valve is bad.. won't start when its cold unless i keep giving it a little gas till it warms up and then it' will idle fine.. also my temp gauge goes up really really slow.. need new thermostat? anyone confirm?
Old Oct 13, 2005 | 04:12 PM
VRD^sam's Avatar
Default Re: LS into 98 coupe (b_serious)
new motor
Old Oct 13, 2005 | 04:18 PM
unknown0001's Avatar
do a good coolant flush you might have air in the lines cloging up.
If not then replace the thermostat
Old Oct 13, 2005 | 04:32 PM
b_serious's Avatar
Default Re: LS into 98 coupe (Mr.RHTuner)
ill try the thermostat 1st..
Old Oct 13, 2005 | 04:46 PM
blackeg's Avatar
do both. t stats are like 15 bucks at your local parts place, and coolant should only be like 10 bucks
Old Oct 13, 2005 | 05:54 PM
b_serious's Avatar
Default Re: LS into 98 coupe (blackeg)
how could i do a good flush? just draining it prolly isnt enough some kinda air pump?
patpeery
Honda CR-V & Element
Nov 23, 2015 06:50 AM
1fastvtec
Jan 26, 2015 05:12 PM
OoAoO
10
Nov 13, 2013 02:56 PM
siksdb8
Jul 26, 2007 10:06 PM
b_serious
Nov 7, 2005 11:28 PM
