Civic OEM CD install
I just bought an OEM Honda Civic cd player (display unit with the cd acceptor integrated, not the one where the acceptor is next to the cup holder) and was wondering if anyone hads tips on swapping them?
This is on a a 97 Civic ex.
I tried to search but was unsucessful.
TIA
TIA
What are you wanting to know? How to remove the old one? They should just swap right out when you get down to it.
Go to http://www.installdr.com to find out how to remove it if that's what you're asking.
Yes, you need the wiring diagram of the car it came off of and your car's wiring diagram. Then just match wires. I want to do this but i'm having hard time finding stock cd players...
and i don't trust ebay either....
http://installdr.com/InstallDocs/Honda/Civic.html
you do use the lower tray and it shold be plug and play.
you need an adaptor to make this fit in the spot on the dash that has the oem deck. It's easier to just use the din pocket.
also if you have OEM keyless entry, the keyless entry brain is in the OEM radio, so if you unplug the OEM radio your keyless won't work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. ****** »</TD></TR><TR><TD CLASS="quote">also if you have OEM keyless entry, the keyless entry brain is in the OEM radio, so if you unplug the OEM radio your keyless won't work</TD></TR></TABLE>
very very true... i found out the hard way
But now I have the old one tucked behind the lower center console and my new HU in the normal spot and it all works
CBL9
Sep 24, 2007 08:08 PM
