Newer stock radio in '92 hatch
Yes, but you will need to re-wire it, since Honda changed their radio plugs around '98 or so. The wiring diagrams can be found here (Adobe PDF file).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pln81 »</TD></TR><TR><TD CLASS="quote">I was wondering if a Newer (2000+) stock radio would work in a '92.
Thanks</TD></TR></TABLE>
yes, you can buy a harness or two to make it work. check out your local car audio store to buy the harnesses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pln81 »</TD></TR><TR><TD CLASS="quote">so one from '97ish should work fine then?
Thanks for the help
yes
Thanks for the help
yes
!EDWARDS!
15
Jun 19, 2004 02:15 PM
