Car won't start, fuel pump not priming.
Old Oct 14, 2005 | 08:07 AM
lgn1281's Avatar
Default Car won't start, fuel pump not priming.
94 coupe ex. Car not starting, ingition good, no fuel pressure, fuel not priming. New fuel pump and main fuel relay installed. Pump still does not prime with key at on position. No power to pump. What else could be problem???
Old Oct 14, 2005 | 08:11 AM
snatch's Avatar
Default Re: Car won't start, fuel pump not priming. (lgn1281)
There isn't a fuse for the fuel pump is there? Just a shot in the dark.
Sounds like you've checked the basics.
Old Oct 14, 2005 | 08:22 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Car won't start, fuel pump not priming. (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">There isn't a fuse for the fuel pump is there? Just a shot in the dark.
Sounds like you've checked the basics.</TD></TR></TABLE>
I think it might be one of the big black ones under the hood
Also try this:
https://honda-tech.com/zerothread?id=1320931
Old Oct 14, 2005 | 08:26 AM
duggy's Avatar
There is a fuse called the ACG fuse under the dash.
I had this same problem a couple weeks ago. I changed the ACG fuse and it worked.
m.glisson003
Oct 31, 2011 05:53 PM
snzh22
Aug 8, 2007 04:53 PM
b16acrxer
Nov 13, 2003 07:21 PM
