Upper control arm install
Ok. I know the removal of the upper control arm (front) is quite easy. But, to put it in, there isn't alot of clearance to place a jaw puller to push it back in. If I tighten the hex nut, will it just snap into the knucke?
It's cake, really. Since you're not going to reuse the old balljoint from the old control arm, you can hammer the end of the stud to push the joint out. It goes back in pretty easy as well. Took me ~5 minutes per side. And I was drinking a beer while I did it.
thisboyjulio
Oct 23, 2006 08:34 PM
