94 del sol, clunking problem! driving me NUTS
Old Oct 13, 2005 | 10:51 AM
rainydayman's Avatar
Default 94 del sol, clunking problem! driving me NUTS
whenever i rev from 1st or 2nd gear and somtimes when i come to a full stop, i would hear a clunking sound from the rear. is it the exhaust, wheel bearings, suspensions or WHAT. anyone have this problem before or have an idea or what it is?
Old Oct 13, 2005 | 10:55 AM
david
Guest
Posts: n/a
Default Re: 94 del sol, clunking problem! driving me NUTS (rainydayman)
your car droppeD?
Old Oct 13, 2005 | 10:57 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 94 del sol, clunking problem! driving me NUTS (david)
check all your motor mounts
Old Oct 13, 2005 | 11:10 AM
IHateJDM's Avatar
and there's nothing rolling around in your trunk?
Old Oct 13, 2005 | 11:54 AM
Default Re: 94 del sol, clunking problem! driving me NUTS (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david &raquo;</TD></TR><TR><TD CLASS="quote">your car droppeD?</TD></TR></TABLE>
nah my car is not dropped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">and there's nothing rolling around in your trunk?</TD></TR></TABLE>
haha, that was the first thing i checked -.-
Old Oct 14, 2005 | 08:36 AM
david
Guest
Posts: n/a
rear shock(s) is/are blown probably... i'm slammed on stock w/ h&r race springs. the moment i put them on, my shocks went and i got that sound. they were already bad to begin with. i get that noise on both sides.
Old Oct 19, 2005 | 11:27 AM
for anyone having the same problem, it could be ur lugnuts. a lugnut may not be completely centered when tightened so when u accelerate or brake it causes the wheel to slip and clunk. PEACE
Old Oct 19, 2005 | 11:32 AM
snatch's Avatar
Seems like you would have to have more than one lugnut loose though. The other 3 would pull the wheel where it needs to be and then the other one would just be loose. Shouldn't be that hard to get lugnuts on there right anyway. They either thread smoothly or they don't.
Either way, check for shocks and see what kind of condition they're in. See if you can see any fluid leaking from them anywhere. Make sure everything is tightened up back there. If you have a custom exhaust, you might also check for clearance issues with that.
VTEC_PRODUCTION
15
Mar 28, 2007 01:04 AM
Sly_Samba
Sep 16, 2006 09:00 AM
luder2_2vtec97
Aug 18, 2006 10:41 AM
ek_slut
10
Apr 19, 2005 06:59 AM
Drag-On
Apr 4, 2005 07:45 AM
