automatic transmission shifting
Old Oct 12, 2005 | 08:04 PM
masteroflife67's Avatar
Default automatic transmission shifting
i have a 2000 civic, with a 4-speed automatic transmission. i know that downshifing helps deceleration and cornering, but at what speeds should i downshift/upshift?
Old Oct 12, 2005 | 08:15 PM
TurboFart's Avatar
Default Re: automatic transmission shifting (masteroflife67)
dnot worry about waht speeds to shift, ITS AUTO.
Old Oct 12, 2005 | 08:16 PM
Default Re: automatic transmission shifting (TurboFart)
yeah, but i'm trying to squeeze every bit out of it lol.
Old Oct 12, 2005 | 08:18 PM
HBADGE's Avatar
I heard its bad to put an auto into neutral while at a stop light or slowing to one. By this I mean like man. trans.
Old Oct 12, 2005 | 08:30 PM
G2 Speed's Avatar
Default Re: automatic transmission shifting (HBADGE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBADGE &raquo;</TD></TR><TR><TD CLASS="quote">I heard its bad to put an auto into neutral while at a stop light or slowing to one. By this I mean like man. trans.</TD></TR></TABLE>
wrong
if you got an auto and you shift into neutral during long stops.. it takes load of the engine/tranny and saves gas
do a 5spd swap
Old Oct 12, 2005 | 08:34 PM
TurboFart's Avatar
its not really bad, but just not necesary? you're still gonna have to hold the break, just pull up e-break, and the only time its really bad is if you nuetral drop (rev in neutral and push into drive since u dont need to push button in), and if u wanan squeeze every bit out of it, just floor it when your think its gonna need to GO ahead.. example: goin into a turn slow down, then before you get to the point where you accelerate, floor it a little early since it will downshift for you, it still takes more time than being manual knowing when to do it, im sure theirs other ways to 'squeeze' everything out of it, but i drive manuel so wtf do i know
ekcivic9's Avatar
since theres no clutch to an auto, is it safe to "Shift" into neutral say when you are going 50mph in d4?
Old Oct 12, 2005 | 09:00 PM
O16581724 5 2 5's Avatar
Default Re: (ekcivic9)
No clutch in an automatic? They work on practically nothing but clutches. Do not manually shift your automatic, it wears the clutch bands, put it in drive and go.
Old Oct 12, 2005 | 09:06 PM
Blk00EJ8's Avatar
Default Re: (O16581724 5 2 5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">No clutch in an automatic? They work on practically nothing but clutches. </TD></TR></TABLE>
You beat me to the punch.
Old Oct 12, 2005 | 09:36 PM
ekcivic9's Avatar
i meant physically. a 3rd pedal.
-edit- nvm. im out of it today.
masteroflife67
Oct 13, 2005 06:28 AM
Campee
Mar 25, 2005 11:03 PM
suspendedHatch
Apr 25, 2004 03:48 PM
JonGP4
Jun 12, 2003 08:48 AM
VTECTIME
29
Aug 31, 2002 07:33 PM
