battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8
Old Oct 14, 2005 | 02:39 PM
Bense's Avatar
Default battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8
so i've searched and searched but i haven't been able to find anything.
I am currently building a crazy setup with a y5 head and i'm looking for a d16 block. A friend of mine has a d16a6 block, but i don't know if it would be better to get this a6 or look for a d16y*
i know that they all nearly identical, but what's the differences between these?
Old Oct 14, 2005 | 02:44 PM
VTC_CiViC's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (Gordon Liddy)
The fundamental architecture of the D-series hasn't changed in some 15+ years, there have been small revisions made here and there, but nothing to really give one block a clear advantage over another. From my experience, it seems like the Y variants tend to spin bearings less often than their Z cousin's, but that's just my observation. Personally, I'd go for the newest possible block just for the low-mileage factor.
Old Oct 14, 2005 | 02:46 PM
Bense's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">The fundamental architecture of the D-series hasn't changed in some 15+ years, there have been small revisions made here and there, but nothing to really give one block a clear advantage over another. From my experience, it seems like the Y variants tend to spin bearings less often than their Z cousin's, but that's just my observation. Personally, I'd go for the newest possible block just for the low-mileage factor.</TD></TR></TABLE>
i have thought about this, however i plan on putting new rings, bearings and seals in whatever block i end up with.
Old Oct 15, 2005 | 09:50 AM
Bense's Avatar
top
Old Oct 15, 2005 | 10:07 AM
bluemax189's Avatar
first off, why the Vtec-E head. that is probably the worst one you could use. just go buy a complete Z6. even though i have a turbo y8, the z6 is easier because of the obd1.
Old Oct 15, 2005 | 10:33 AM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">first off, why the Vtec-E head. that is probably the worst one you could use. </TD></TR></TABLE>
lol very true...you wont be going very fast at all, but you can save gas...
i would just say put on a z6 head w/ a y8 headgasket and be done
Old Oct 15, 2005 | 04:38 PM
Bense's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (sockvtec)
come on guys, ROLLER ROCKERS AND A MORE AGGRESSIVE CAM!
Old Oct 15, 2005 | 06:22 PM
FalkenSiR's Avatar
You guys have forgotten the JDM D16A, 140hp SOHC VTEC came in (as far as I know) the few EG coupes that came out in Japan and the 92-95 Domanis. That, my friends is the best D series motor imo. Rare but existant.
Old Oct 15, 2005 | 07:22 PM
.Beaver's Avatar
Bloody Beaver
In my area I personally know of at least 10 people with spun bearings in y8's, and only 1 spun bearing in a z6 (i did it... with nitrous)
Old Oct 15, 2005 | 11:41 PM
Ace0246's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (Dr. ******)
ditto on the Y8 Bearing issues. Most of the Y8's that end up for sale in my area have a spun bearing in them and around 60k miles or more. Most of the Z6's are still running strong, and they have 150k + on them.
Old Oct 16, 2005 | 12:19 AM
Jorsher's Avatar
ummm damnit I have a y8, just curious if I don't run it to 6k rpm every day like I currently do will it be alright?
Old Oct 16, 2005 | 03:59 PM
sockvtec's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">You guys have forgotten the JDM D16A, 140hp SOHC VTEC came in (as far as I know) the few EG coupes that came out in Japan and the 92-95 Domanis. That, my friends is the best D series motor imo. Rare but existant. </TD></TR></TABLE>
hmmm never heard or seen anything bout it....do you have anymore info on it?
Old Oct 16, 2005 | 05:52 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
a6.
Old Oct 16, 2005 | 06:00 PM
d16singlecammer's Avatar
He means the JDM SOHC ZC VTEC, which are not rated at 140 but more like 130. Identical to the D16Z6 but there are rumors that it comes with a more aggressive cam.
Old Oct 16, 2005 | 06:01 PM
CoreyR's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (floss)
from what ive read A6's are supposedly the best cause they have steel or iron (forget which) main caps not aluminum like 92+ D's.
Old Oct 16, 2005 | 06:30 PM
sohc dude's Avatar
complete z6, y8 headgasket, y5 sparkplugs works best i think
Old Oct 16, 2005 | 06:43 PM
Skynet's Avatar
Default Re: (sohc dude)
ZC is dohc non vtec
Old Oct 16, 2005 | 07:00 PM
Default Re: (Skynet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skynet &raquo;</TD></TR><TR><TD CLASS="quote">ZC is dohc non vtec</TD></TR></TABLE>
Wrong, ZC came in two sohc forms, one vtec OBD1 and the other non vtec OBD0. Along with the DOHC ZC version
Old Oct 16, 2005 | 08:30 PM
racerpat94's Avatar
Default Re: (d15singlecammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">from what ive read A6's are supposedly the best cause they have steel or iron (forget which) main caps not aluminum like 92+ D's.</TD></TR></TABLE>
correct. this is a great block to use because of its strength. i would go with a JDM d15b, an a6 or a z6 in that order. since youre already building a head, the factory HP levels are going to be the same anyway. the JDM d15 has slightly smaller displacement, but has a better R/S ratio and is more suited for high rpms. stay away from any of the Y motors. they have a re-designed oil pump that restricts oil flow by over 35%. THAT is why people with EK+ civics report more spun bearings.
Old Oct 17, 2005 | 12:12 AM
Skynet's Avatar
right on
Old Oct 17, 2005 | 12:47 AM
FuNkDrSpOt's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (Ace0246)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace0246 &raquo;</TD></TR><TR><TD CLASS="quote">ditto on the Y8 Bearing issues. Most of the Y8's that end up for sale in my area have a spun bearing in them and around 60k miles or more. Most of the Z6's are still running strong, and they have 150k + on them.</TD></TR></TABLE>
I can add to the statistic. My Y8 just spun 2 bearings. That thing was taken care of and it still **** a brick on me. All i had was I/H/E and an AEM cam gear set @ +4
Old Oct 18, 2005 | 08:52 PM
racerpat94's Avatar
Default Re: battle of the d16 blocks: d16a6, d16z6, d16y5, d16y7, d16y8 (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">
I can add to the statistic. My Y8 just spun 2 bearings. That thing was taken care of and it still **** a brick on me. All i had was I/H/E and an AEM cam gear set @ +4</TD></TR></TABLE>
yep. my neighbor is a 40-ish yr old woman with an 98 automatic 4dr LX. she spun a bearing around 85k last year. does that mean that the y-series motors are junk? no, but if you are planning on quickening your engine up, i would avoid them. good oilflow keeps your engine alive.
Old Feb 9, 2010 | 11:07 AM
zachrikature's Avatar
That might be a stretch. Oil pumps from y's are what destroys them, they **** the bed all the time. The way to do it is swap out the y oil pump for say a z6 oil pump and you should be golden.
Old Feb 10, 2010 | 04:20 AM
noremorseracing's Avatar
my buddy just hit 320k miles in a d16z6 stock 94 ex coupe. i would either do the z6 or a d16a6 with a d16z6 head(to keep it odb1 less wiring issues)
Old Feb 10, 2010 | 04:48 AM
eghatch4sale's Avatar
If u are looking to build a motor for n/a why not run the d16b5 it stock is 12:5:1 compression
