How do you shave letters off the valve cover
Be careful if you do it by hand with a dremel or something. It's hard to get the surface completely flat.
It can be done, but it takes a while.
I would start out with a dremel to take most of it down, and then once the letters are just barely raised I'd go at it with a hand sander.
Belt sander could work too, but just be careful and go slowly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">Be careful if you do it by hand with a dremel or something. It's hard to get the surface completely flat.
Belt sander could work too, but just be careful and go slowly. </TD></TR></TABLE>
You always have good advice Lincoln!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">It's hard to get the surface completely flat.
Totally Agree!
Totally Agree!
don't shave the vtec off.....get a 92-93 valve cover with the H to do it. Less material to grind and most people will pay more for vtec covers anyways. That's if your talking about a d-series at least. Otherwise, it depends on what your going to paint it with. If you're using wrinkle paint, id just use a 4 inch grinder(what i used)...you won't notice the "waves" with wrinkle paint. If your using a high gloss paint, i would grind it down most of the way and then use sandpaper and a block to get it smooth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vado-Ieiunium »</TD></TR><TR><TD CLASS="quote">You could've got another cover for like $15</TD></TR></TABLE>
another valve cover??
where at for $15
where at for $15
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxsteve803xx »</TD></TR><TR><TD CLASS="quote">LS valve cover doesnt have VTEC on it.....mayb that will fit
ls valve covers dont fit on the b16, but if they did, can you imagine how many ricers would put a vtec valve cover on there LS motors.
</TD></TR></TABLE>ls valve covers dont fit on the b16, but if they did, can you imagine how many ricers would put a vtec valve cover on there LS motors.
Guest
Posts: n/a
How come you wanna shave that off? i'd be happy to have those precious letters engraved in my valve head(i have D15 SOHC non-vtec poo poo
). unless i' was going for ultimate sleeper i'd leave em.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx »</TD></TR><TR><TD CLASS="quote">I'm going to paint my valve cover and i was wondering how i could shave the Vtec off</TD></TR></TABLE>
I use a Gillette Mach 3. works wonders and the special soothing strip helps fight oxidation
ShinotakuX
11
Jun 26, 2007 09:52 PM
