96 Civic EX B16A2 Throwing codes 67 and 90
I checked my cel's. One was 90 which is Evaporative Emission Control System leak detected in the fuel tank area and 67 which is Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system.
I plugged up a obd2 scanner and it said 1 out of 3 codes are thrown. I got p040 and p1457 twice. I think code 67 i can fix because the plug on the cat might have gone loose.
What should i do?
What should i do?
The evap one will also happen if you have forgotten to plug in the sensor to your charcoal canister. Check that connection as well.
b 1 6 a 2
Dec 20, 2004 04:26 AM
