Solid CEL (Search down!)
Old Oct 13, 2005 | 01:02 PM
pdiggitydogg's Avatar
Default Solid CEL (Search down!)
I have a solid cel...wtf does that mean?
The car became very jerky on and off throttle, because of it.
I was not limited in rpm.
This happened awhile after I followed some POS car up an on-ramp, that blew basically soot out its exhaust. Could this be the only reason?
Old Oct 13, 2005 | 01:10 PM
IHateJDM's Avatar
Default Re: Solid CEL (pdiggitydogg)
do you mean it came on solid, or it stayed solid when you jumped the connector?
Old Oct 13, 2005 | 01:13 PM
with jumped connector
Old Oct 13, 2005 | 01:16 PM
IHateJDM's Avatar
Default Re: (pdiggitydogg)
that's the code for bad ecu. did you ever smell that notorious circuit board burning smell?
Old Oct 13, 2005 | 01:42 PM
****...thats the last god damn thing I want to worry about
No, never noticed any smells, but I drive with the windows down as much as possible...
Old Oct 13, 2005 | 01:47 PM
IHateJDM's Avatar
chipped ecu? a bad chip will do that too. possibly some really messed up wiring.
Old Oct 13, 2005 | 01:59 PM
The_Head's Avatar
Default Re: (IHateJDM)
How does the car run if the ECU is fried? Is there one last backup MAP on a circuit that is unused normally?
Old Oct 13, 2005 | 02:01 PM
IHateJDM's Avatar
Default Re: (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">How does the car run if the ECU is fried? Is there one last backup MAP on a circuit that is unused normally?</TD></TR></TABLE>
it doesn't have to be completely fried. I had a bad chip one time, got the solid cel. Car ran, but ran like complete crap.
I went out and reset the ecu (interesting thing to do at school) and the car starts and seems to run fine.
I drove it around the lot and no probs, but I havent taken it on the road yet....I'll be doing that around 10pm after class...
Old Oct 13, 2005 | 02:18 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I have a solid cel...wtf does that mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">with jumped connector</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">that's the code for bad ecu. </TD></TR></TABLE>
No, that means there are no stored trouble codes. The ecu is fine.
Old Oct 13, 2005 | 04:52 PM
blcivsi's Avatar
is the check engine light on without the jumped connector. if it is you should be able to get a code. if no codes probably ecu. if light is off without jumper you shouldn't get any codes. ecu is fine
Old Oct 13, 2005 | 05:28 PM
aspec101's Avatar
solid cel means a bad ecu, faile checksum, bad chipping job. Hope that helps
Old Oct 13, 2005 | 05:34 PM
I know how to check for codes guys...I wrote a how-to!
Got a code this time
14
IACV...yippie
reported for lock
TurboBA8
Feb 20, 2007 07:25 AM
erikiksaz1
Jan 17, 2007 10:39 AM
cheehee
Sep 6, 2006 05:02 PM
THEUSED
Apr 16, 2006 10:18 AM
THEUSED
Mar 5, 2006 06:23 PM
