Del sol Power window all screwed help!
All my windows in my del doesn't work at all. Check all my wires and everything is in tack. Check my fuses wasn't that and even replaced the main power window control module wasn't that either. Does the del sol have a power window relay? If so where the hell is it and whats the stock numbers on it? Went to the Honda dealer and ask for help. They told me to take out the relay and they could get me a new one. ******* idiots how the hell am I suppose to do that if I don't know where it is my self. Three months training still doresn't help the idiots down there. Also is this suppose to mean something. When I press on my switches to the window it make a click sound around the control module? Thanks a lot people, it can get hot in the car lol.
First check all 15amp fuses under ur steering colum, then check all fuses in the fuse box located in the engine bay. Take off the door panel and ensure contact with the green plugs.
I had to open up my driver side door 6 times one day because my wires were interfereing with the window tracks. grease or wax the window tracks; buy a multimeter and test all ur connections.
It took me all of 3 min to find my plugs looked connected however they needed to be pushed together a bit more.
You may also try relacing the switches, they are fairly enexpensive... 15$ on ebay 40-120$ from honda parts in japan.
I didn't look close enough @ ur post...... buy a new relay or 80-90amp fuse fuse is 4$ and a honda relay will run you 25-30$... Again a multimeter is cheap enough and a great reasource for trouble shooting electrical problems.
I appreciate all you guys help. I check all the fuses and replace all that needed. I still didn't get know play. So I open the panel and slice the power wiring from the window motor and gave it power from the battery. I heard the window roll down then it made a shock sound. I guess Something is blocking my power to the motor. When I attempted to put power directly to the motor I must have blew my power window module I just bought. I could smell a burning smell when I took it out. If My window rolled down when connected to the battery. Then what is my problem? I'm think it the power window relay right?
sirbradalot
Apr 18, 2011 07:10 AM
