code 22 , change the oil pressure switch or entire solenoid ???
Old Oct 14, 2005 | 02:53 AM
cioli's Avatar
Default code 22 , change the oil pressure switch or entire solenoid ???
i have code 22
enough oil
power on cables it's ok
vtec solenoid inside it's clean
should i buy a new green sensor ( oil pressure switch ) or entire solenoid
thank you in advance
Old Oct 14, 2005 | 05:35 AM
93CX's Avatar
Default Re: code 22 , change the oil pressure switch or entire solenoid ??? (cioli)
code 22 is for the pressure switch. does the CEL come on when you start the car or when you get in VTEC rpm range?
Old Oct 16, 2005 | 10:04 AM
cioli's Avatar
Default Re: code 22 , change the oil pressure switch or entire solenoid ??? (93CX)
cel pops on at 180 or 190 km/h ( kind a 120 miles )
on 1 and 2 gear runs ok i can say but on 3 ,4 ,5 it kicks in and out ...almost no vtec
sometimes does not work properly neither on 1 and second gear ..how does it wants
it can be the pressure switch bad and the vtec still working a little ? or if it's bad there is absolute no vtec ?
Old Oct 17, 2005 | 04:53 AM
cioli's Avatar
bump for some help please
Old Oct 17, 2005 | 06:31 AM
93CX's Avatar
Default Re: (cioli)
Its probably not the wiring but you should check that anyway. Is this a swapped car? I cant tell what you said, is VTEC coming on at all or only sometimes? How is your oil level? Just do a search for VTEC troubleshooting and I'm sure you can find your answer.
Old Oct 17, 2005 | 07:04 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Have you checked the oil with the car on level ground?
I don't think I've ever seen a car throw that code with the correct amount of oil in it.
Old Oct 17, 2005 | 07:57 AM
cioli's Avatar
YES i have a lot of oil
i did a lot of searchings trust me , didn'y fiind what i want
so my vtec works but not how it should , it kicks in and out at high speeds especially in 3 , 4 and 5 gear , and at 120 miles check engine pops on
it is possible that the oil pressure switch is working but not how it should ?
Old Nov 27, 2005 | 06:36 AM
cioli's Avatar
Default Re: (cioli)
i changed the switch with a new one still a shitty vtec
nobody can fix my car here in Romania
on lower speeds vtec works ok but after 3rd , 4th ,5th gear it kick in and out ( needs more oil pressure maybe ? )
it's possible that its something bad in the engine causing low oil pressure ?
my oil light stays on just a few seconds in the morinng when i start my cat but then it dissapears - so pressure it's ok ?
solenoid seems clean , screen its ok too
at about 110 miles ( sometimes lower ) check engine pops on and it's code 22 ( oil pressure switch )
i saw that when my oil it's new changed works little better , so it's something related with oil pressure
maybe its something clogged ? in the oil pan ? but if it was clogged then my oil light will stayed on right ?
help please
he has the same problem : https://honda-tech.com/zero...80792
Modified by cioli at 7:46 AM 11/27/2005
Modified by cioli at 7:48 AM 11/27/2005
Old Dec 1, 2005 | 11:48 PM
dc4rider's Avatar
Default Re: (cioli)
try cheacking the ground on the oil switch i had that problem
Old Feb 24, 2006 | 05:29 PM
Charlie Moua's Avatar
Default Re: (seditionONE)
I'm having this issue with my stock vx......
code 22.
oil level is good.
code comes on right when I start the car.
Old Feb 24, 2006 | 09:41 PM
D16Z6TURBO's Avatar
similar prob with my JDM B16 but get this it doesnt have a pressure switch but it still has VTEC till 3rd WOT@7500rpm then I get code 22. The spot where my press switch goes isnt tapped for a switch WTF any thoughts ppl
Old Feb 24, 2006 | 09:48 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Last time I had this problem I found the individual who sold me the motor had glued the green connector back to the housing... obviously I fixed the connection by replacing it as well as the top solenoid with the one wire grey connector. Problem was solved.
Old Feb 26, 2006 | 08:31 AM
D16Z6TURBO's Avatar
Has anyone heard of this problem being caused by the JDM ecu and not requiring a vtec press switch? I have heard that several JDM systems only run the single wire vtec solenoid and no press switch. Im leaning toward believing this since my JDM engine did not come with one I tapped it and added one but still having same issue startin in 3rd at 8000rpm except my comp just goes into limp mode till I flip the key
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
missionaryrider
Dec 9, 2007 01:50 AM
wernhersey
Apr 15, 2007 07:48 AM
drudy
Aug 26, 2005 12:20 PM
drudy
Aug 7, 2005 05:59 AM
