code 43 and the engine cuts out what could it be??plz someone help out
Old Oct 12, 2005 | 07:33 PM
lshatch1.8's Avatar
Default code 43 and the engine cuts out what could it be??plz someone help out
hey guys im getttin code 43(fuel supply) and the engine cuts out now it has been on for a while doing nothin but now the engine cuts out. What should i replace or were should i start?? i have a extra set of fuel injectors(but there non vtec) should i put those in to see if the code stops? i seen that there is a code for injectos i think 43 so would it pop up if one of the injectors was bad? or should i try to change the fuel pump? i can get a buddy at the junkyard to let me borrow one out of a sohc vtec civic? if anyone has had this and fixed it plz let me know what it was thanks alot
Old Oct 12, 2005 | 07:53 PM
lshatch1.8's Avatar
Default Re: code 43 and the engine cuts out what could it be??plz someone help out (lshatch1.8)
bump guys i need to fix this problem also does anyone think it could be the fuel filter?????
Old Oct 12, 2005 | 09:28 PM
lshatch1.8's Avatar
i have searched all night and havnt found anything i searched for fuel pump and main relay i really dont have a clue what it could be if anyone has anything to say plz say it even if its dumb i just dont know were to start or anything thanks
Old Oct 12, 2005 | 10:01 PM
turb@d18jdm's Avatar
wen does it cut off???
Old Oct 13, 2005 | 09:18 AM
lshatch1.8's Avatar
Default Re: (turb@d18jdm)
it does it on normal driving the code has been on for ever and it just started bogging what does out after time? the fuel pump?injectors? plz someone help out
Old Oct 13, 2005 | 01:21 PM
lshatch1.8's Avatar
Default Re: (lshatch1.8)
i changed the fuel filter and the ligth is still on i tryed to check it for code 43 and it never came it just keeps going and going....! i drove the car just a little bit and it didnt studer but i didnt drive it enought to tell.. i did check the plugs and they had white tips! the filter was a bit dirty and the injectors had black **** all at the end. Does anyone know what it could be. And do fuel pumps just go out right away or slowly??
Old Oct 13, 2005 | 02:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch1.8 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys im getttin code 43(fuel supply) and the engine cuts out now it has been on for a while doing nothin but now the engine cuts out.
if anyone has had this and fixed it plz let me know what it was thanks alot</TD></TR></TABLE>
If your fuel presure stays within spec, it's likely your o2 sensor.
Old Oct 13, 2005 | 02:33 PM
lshatch1.8's Avatar
Default Re: code 43 and the engine cuts out what could it be??plz someone help out (Chiovnidca)
ive never heard of an o2 sensor maken a car cut out???
Old Oct 13, 2005 | 02:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch1.8 &raquo;</TD></TR><TR><TD CLASS="quote">ive never heard of an o2 sensor maken a car cut out??? </TD></TR></TABLE>
It happens. Check your fuel presure when it's acting up first to rule that out.
shoklid
Apr 28, 2009 06:19 AM
SsB_Db8
Jul 14, 2007 11:25 PM
neuerasd9
Feb 16, 2006 01:58 PM
cincispeedemon
Nov 22, 2004 05:51 PM
Cole D
Jul 10, 2003 08:25 PM
