How do you remove the EG steering wheel? Search turned up no results
Old Oct 12, 2005 | 06:57 PM
preludepower's Avatar
Default How do you remove the EG steering wheel? Search turned up no results
Hi all. Right now I'm doing the integra dash swap into my '92 civic. I've been working on disconnecting the civic dash for the last hour or so, and it is now ready to come out...
The only problem is that I don't see how it will fit over the steering wheel. I lowered the steering column to it's lowest point, but I still can't see how I'll get it out.
It would be a lot easier to just remove the steering wheel.
How do I remove it?
Thanks
Old Oct 12, 2005 | 07:01 PM
aspec101's Avatar
Default Re: How do you remove the EG steering wheel? Search turned up no results (preludepower)
Disconnect battery, unbolt and unplug the air bag. One 19mm nut holding on the wheel have fun.
Old Oct 12, 2005 | 07:03 PM
O RLY's Avatar
No no no. Listen... You need to pop the cover off of the side of the steering wheel. Its an 'L' shaped piece of plastic, just use a flathead. Then on the other side where the cruise control is take that piece off. Unscrew both Torx screws and the airbag will pop off. Disconnect it (disconnect the battery upon reinstallation just in case.) Then take a socket that fits the big nut under the airbag (I can't remember, maybe a 15mm) and remove it. The steering wheel will slide right off. Oh yeah, and remember how you took the wheel off, cuz when you put it back on, you're gonna want it to be perfect, or you'll be driving straight, but the steering wheel will be turned a bit. Good luck.
Old Oct 12, 2005 | 07:04 PM
O RLY's Avatar
Default Re: How do you remove the EG steering wheel? Search turned up no results (vaperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaperformance &raquo;</TD></TR><TR><TD CLASS="quote">Disconnect battery, unbolt and unplug the air bag. One 19mm nut holding on the wheel have fun.</TD></TR></TABLE>
Yes yes yes. I wasn't correcting you man, you posted while I was typing my reply.
Old Oct 12, 2005 | 07:14 PM
Default Re: How do you remove the EG steering wheel? Search turned up no results (JDMH22Civic)
Ok great thanks....although I don't have cruise on my car
and by the way I also have an H22 in my civic....lots 'o' fun!
Hopefully it'll come off as easily as you said.
Old Oct 12, 2005 | 08:17 PM
Thank you for the accurate advice. Steering wheel came off just as you said.
htwitr01
Jul 8, 2010 07:13 PM
qwrty
Oct 29, 2009 01:55 PM
DC5mike
Jan 12, 2008 08:15 PM
hanskies
May 24, 2006 03:34 PM
Jdmdc4ls
Apr 24, 2006 12:15 PM
