Bench-Bleeding a Master Cylinder
So I would search for this if the search server wasn't unavailable at the time of posting..
I wanted to go ahead and throw in the Si M/C into my civic just because I have it. I read something about how you have to "bench bleed" it. Any specifics on doing that? I know how to bleed the whole brake system.. so I assume this is something different.
the way to bench bleed is to run 2 rubber hoses from the ports back into the reservoir submerge them and pump the piston till bubbles stop coming out. if you dont have a bench bleed kit, just put your fingers over the ports, and pump the piston, keeping them covered on the rebound, untill you stop getting air out of the ports.
Voodoo7
Jan 30, 2012 09:47 PM
dirtycolombian
13
May 20, 2007 01:53 PM
mingchi69
Jun 23, 2003 06:25 PM
